Old March 23, 2009, 08:54 PM
Apollo4g's Avatar
Default Lapped my i7
Well i finally got around to lapping my i7.
Temps are about 2-3C better on load but i mounted the block in a hurry and will do it properly once i move to my TJ07 build.
Here are the pics of the process.
Wow the i7 is very unflat as you can see, the middle and corners really needed to be sanded town quite a bit.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old March 23, 2009, 09:06 PM
zlojack's Avatar
Nice!
I've been thinking about doing the same thing as mine definitely looks uneven.
The chip I've got does 4GHz at 1.35 but runs a lot hotter than the other two that did lower speeds at the same volts.
Old March 23, 2009, 09:24 PM
MpG's Avatar
MpG MpG is offline
Interesting. That's actually fairly close to what my processor's IHS looked like, I think. I think I got a degree or two improvement, although I presently have temperature problems with my processor, so it's hard to say for sure.
Size:  37.8 KBName:  Lapping4.JPG
Old March 23, 2009, 09:32 PM
funny how its bowed OUT not IN
Old March 23, 2009, 09:35 PM
Chilly's Avatar
Takes alot of balls, personally I'm not sure voiding the warranty is worth 1c or 2c better temps.
Looks great regardless!
Old March 23, 2009, 09:43 PM
MpG's Avatar
MpG MpG is offline
No kidding. Definitely different than the horrible Q6600's. I guess that means (assuming this is the norm) that even stock, we can expect good centre-point contact between the IHS and heatsink, so minimal gains from lapping.
Old March 23, 2009, 10:12 PM
bovine.baron's Avatar
I hear that. My E5200 was so concave I went into lapping intending to get it as flat as possible no matter how long it took! But after I only had minor grooves in a razor test, I got so bored that I started checking every 50 laps or so and decided screw it, I'm not patient enough for this
Old March 23, 2009, 10:19 PM
gingerbee's Avatar
you and me both i might try this if i buy an upgrade but for a 1 to 2 c drop is it really worth voiding (nice job by the way)
Old March 24, 2009, 10:07 AM
belgolas's Avatar
Um isn't overclocking voiding the warranty anyways?
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old March 24, 2009, 10:25 AM
lemonlime's Avatar
Hardware Canucks Reviewer
Looks good! I did the same with my old Q6600. I couldn't believe how much material came off before the processor was flat. Took me quite a while. I found that the mounting pressure of my TRUE was reduced due to my processor being a bit shorter. I still need to lap my TRUE as well, so I'm probably going to need to do the washer trick to increase the pressure by the time I'm done
Lapped my Q6600 and Vendetta 2 Dadi_oh Air Cooling 9 February 20, 2009 09:02 PM
FS: Cherry picked lapped E6850 ES Wankerfx Buy/Sell & Trade 3 May 16, 2008 12:05 PM
FS - Q6600 Lapped, E8400, 4 GB ReaperX PC28000, 8800 GTX zlojack Buy/Sell & Trade 39 March 5, 2008 08:14 PM
lapped e6600 enaberif Overclocking, Tweaking and Benchmarking 17 October 15, 2007 08:24 PM
