Old March 25, 2009, 03:21 PM
Originally Posted by Squeetard View Post
Why do you want to disable it? I've benched everything under the sun with it on or off and there is zero difference. And you save a ton of heat/power with it on.
Yeah I have done many tests
Its okay on here
I guess its personal preference.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
how much ram do you need inable to disable pagegfile? Shadowmeph RAM 7 March 13, 2009 02:26 AM
how to disable keyboard power off key in XP? tao5269 O/S's, Drivers & General Software 6 September 15, 2008 06:44 AM
computer slowing down dabud Troubleshooting 4 June 10, 2008 09:20 AM
How do I manually disable DirectDraw? mrlie3 O/S's, Drivers & General Software 4 June 4, 2008 07:40 PM
How do disable certain core on core2duo in bios P5K neurobashing CPU's and Motherboards 14 September 18, 2007 09:21 AM
