Old March 21, 2009, 04:51 AM
Default i7 920 temps
Just wondering if the temps I'm getting are some what high. my 920 is running at 3.0ghz @ stock vcore. After about 15 mins of prime95 i get 67-66-65-63 on the cores. This is with Thermalright Ultra 120 extreme. This is also with a new application of as5, so I'm hoping temps will drop a bit with time.
Old March 21, 2009, 07:53 AM
Jake_HT's Avatar
By stock Vcore.. what do you mean? lol. 1.1v?
They should be lower than that... I get those temps with HT on at 3.8GHz and 1.3v with that same cooler.
http://jakeht.deviantart.com/
Old March 21, 2009, 07:56 AM
Infiniti's Avatar
Yeah, what Jake said. I'm getting the same load temps as you, with 1.2V @ 3.6. I'm using an Ultima-90 though.
Old March 21, 2009, 10:03 AM
rjbarker's Avatar
Those are warm...should be around Upper 30's with vReg around 48 - 51C at those Clocks at Idle. Those Temps I stated are around Max for idle at your Clocks.
Actually just re-read your Post and those are P95 Temps under load correct...? I wouldn't sweat it too much:
1. What are your Room Temps and Temp within your Case.
2. What are your Idle Temps
3. What is your vreg Temp
Your "Stock Voltage" on your Vcore could be similar to many whereby BIOS sets it to around 1.28v...you'll find at 3 Ghzyou should be able to drop this down signiificantly and lower Temps.
That "Auto" vCore is why so many folks can OC this Chip on "Auto" up to as high as 3.6 - 3.8 Ghz without changing vCore.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 21, 2009, 10:31 PM
The stock vcore is at 1.312v at idle. I'm using Realtemp, not sure if thats the best program to be using to monitor the temps. Not to sure what my room or case temp is, is their a program I can use to see it??. Hmmmm I just came across something, in speedfan is says my cores are 54-54-54-52-52, but in realtemp its giving me 70-67-67-65(this is on load btw). Not sure which was is giving me correct readings. I've also tried reapplying as5, and using different thermal compound, but still same results. Also where can i monitor vreg temp??. Thanks for the help guys = ).
Old March 21, 2009, 10:36 PM
Jake_HT's Avatar
I use realtemp and it works great... Try using coretemp. That sounds unusually high.. Do you have any fans on the T.R.U.E?
Old March 23, 2009, 10:28 AM
RealTemp or CoreTemp are the two that I trust. Like everyone else, your temps seem to be way to high. Did you lap the true and as Jake already asked; do you have any fans on the true?
Old March 23, 2009, 07:00 PM
I think I solved the problem :P. I returned my cpu to stock, and the vcore went from 1.312, to 1.168. Then I ran prime95 stress test to maximum heat, and it only went to 55-54-54-51(sound normal for stock??). So i guess if I'm gonna overclock don't leave the vcore on auto lol.
Old March 23, 2009, 07:29 PM
Sagath's Avatar
Post #4 Man. You should probably fully read the posts when people are trying to help you, instead of just skimming and 'thinking' you got all the info
Old March 23, 2009, 07:51 PM
Chilly's Avatar
What are you talking about? Do you have your view settings on to show newest post first(instead of oldest post first) or what? Because from what I'm reading rjbarker's suggestion solved his issue, that and his(rj's) post IS post #4...
i7 temps gingerbee Overclocking, Tweaking and Benchmarking 1 March 9, 2009 09:02 AM
Are these temps right? overlords Air Cooling 15 January 18, 2009 04:10 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
temps Kassela Troubleshooting 7 March 13, 2008 02:46 PM
GPU temps Infiniti Water Cooling 1 December 23, 2007 10:10 AM
