Old March 20, 2009, 10:46 PM
shayan288's Avatar
Default Cleaning Out Thermal Paste On CPU
Hi guys.
Whenever I have cleaned out thermal paste from my cpu in the past, I used a paper towel, and 70% isopropyl rubbing alcohol. Today I learned, that I was supposed to be using a microfiber cloth, and 99% isopropyl rubbing alcohol. Would what I have done, have caused my CPU any serious damage, or am I alright?
-Shayan
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old March 20, 2009, 10:50 PM
SugarJ's Avatar
You're fine. The 99% is recommended because it dries quicker, and the microfiber because it doesn't leave fluff behind like paper towel can.
I use cotton balls and q-tips myself, with 99% iso.
shayan288's Avatar
oh ok. lol thats a relief!
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old March 20, 2009, 11:23 PM
Chilly's Avatar
Seconded, this is pretty much how I do it.
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Old March 21, 2009, 07:47 AM
sswilson's Avatar
99% + coffee filters. :)
Old March 21, 2009, 07:49 AM
Infiniti's Avatar
Ew, you guys use iso? Paper towels ftw.
Old March 21, 2009, 08:04 AM
Perineum's Avatar
I've always just used brake cleaner. It's got isopropyl and hexane in it. It's meant to not leave a film and I've never seem to have any problem. It's a pressurized can so it cleans in between pins or anywhere it might get. Usually I get it "wet" and leave it a sec, then give it a good blast.
Old March 21, 2009, 08:07 AM
sswilson's Avatar
My only concern with that would be what effect the hexane would have on non-metal components. When I want something aerosol I go with a contact cleaner (electrical cleaner) which allows me to give something a good soaking without worrying about plastic / rubber components.
Old March 21, 2009, 09:13 AM
mklym's Avatar
I use a three step process. First I blast the old TIM with aerosol contact cleaner, then rub off any remaining TIM with a q-tip soaked with contact cleaner. Next I wipe the chip with a new q-tip soaked with isopropyl 99.9%. Final step is to hit the chip with a blast of canned air to make sure there is no fibers anywhere. I tend to error on the over-kill side. :D
Current Rigs
Panasonic Toughbooks
CF-18, CF-19, CF-29, CF-31, CF-52GUN
ThinkPads
X301, A31p
There is always something waiting at the end of the road, if you're not willing to see what it is, you probably shouldn't be out there in the first place.
Life's Journey is not to arrive safely at the grave in a well preserved body, but rather to skid in sideways totally worn-out shouting 'Woo Hoo! What a ride!
Old March 21, 2009, 09:29 AM
yamawho's Avatar
I use acetone and an old t-shirt and have for years.
Caned air after to remove dust if any.
Thermal paste for a phenom II Jonwall CPU's and Motherboards 9 February 6, 2009 05:34 PM
your thermal paste method CTA CPU's and Motherboards 25 December 16, 2008 02:12 AM
Thermal Paste application Mr. Gruntsworthy Air Cooling 9 October 11, 2008 07:18 AM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
Does core2duo come w/ thermal paste Magice CPU's and Motherboards 4 July 12, 2007 03:40 PM
