| Quote:
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| yes ... I know you know all about folding ... and nice frame times too ![]() I just posted the folding reference for the other readers ... and to promote our HCF folding team a bit |
Managed to get over the 450 FSB stable wall I ran into. Currently running (2 hours orthos stable... haven't run it all night for a full 8 hour run) FSB 452 for a cpu-z recorded freq of 3619. Had it up to a windows bootable FSB 459, but even the 452 is taking crazy volts on CPU/NB/SB to get it stable so I'm fairly certain that's as high as I'm going to push it. Something I have found strange compared to my S939 OC experience is the reaction to errors in Orthos. I've found that it'll run fine for 2 hours + (so I know it's already hit max temps) but then sometime overnight it'll just reboot the system rather than reporting an error. I've also noticed this "rebooting rather than orthos error" on lower OC's which just needed a slight vcore bump to overcome. Is this the norm for C2Ds? A64s would either freeze or report an error in Orthos.... I can't recall an unstable A64 OC ever rebooting the system.
I had a fairly rare opportunity to compare the Dark against a pretty close match -- the Gigabyte N650SLI-DS4 -- using the same cpu, ram, vid, psu, etc. This build here was originally spec'd with the P965-S Dark: Case Pics My experience with the board was somewhat of a letdown, we RMA'd it for an exchange to the Gigabyte N650SLi-DS4. On the other hand, it's benchmark numbers were impressive in a number of tests, at stock speed beating out the overclocked Gigabyte! The board was purchased through NCIX in Vancouver BC. It's unfortunate NCIX didn't have another in stock, we would have tried another. Alas, they were out of stock. Why do these places wait till stock is completely out before getting more in?? Gah, it's truely inconvienient, and seems to happen to me all too often. It seems I am constantly sacrificing one part for another, because the one I want isn't in stock. As of June 23, I see they are in stock again. I also see NCIX has added a disclaimer to the product page: Quote:
Have there been significant enough problems with this board to warrant this? And not just isolated things? Or is DFI instigating the policy, not NCIX's decision? Before I saw this, I would have bought another one of these; now? No way. Actually, only one way; if I bought it used off another person and it was verified to function correctly. Anyways, I got one of the last ones they had, at the time. It was a bad squealer. This Dark had a couple other issues, but these were possibly fixable with future bios releases or more tweaking, and also possibly due to other components or combinations:
The Gigabyte incidentally, was able to run 1066 memory with the cpu at stock 266. In linked or unlinked mode, without a hitch, right out of the box. It's the first thing I tried. Orthos stable with 5-5-5-9 timings and only 2.1v on the ram. It does have it's own quirks, but not appropriate to list them all here. There were a few things about the Dark that had me recommend it in the first place, and we were fairly determined that whatever we got would have to have some of these features. As with any new tech, there's bound to be growing pains, and we accept that. I told him right up front to give me a month with this build, we were prepared for delays and extensive burn-in and testing. In the end it was 6 weeks, but it was ready in a month and sat on my out-bench for two weeks until he had time to let me install it. Some of our desired features: all solid caps, digital pwm, extensive bios settings, under $180 or so. So the DFI Dark and the Gigabyte N650 DS4 are actually a pretty comparable match. Their main difference bieng not really so much the chipset, but one being Crossfire and the other beijng SLI. They are both all solid caps, digital pwm, great bios, and almost exactly the same price (at least at the time). Of the smaller differences, one ironic perhaps, the CMOS Reloaded missing on the DFI is present in an even better form on the Gigabyte with their Dual Bios and Bios Setting Recovery gives you a total of 16 savable BIOS setups, 8 each for the two separate cmos chips. Additionally, you can run a different version bios on one chip, letting you test out new bios releases and still instantly boot back to the old original. One major major caveate to this is the cmos chips are soldered to the board. I really like this ability, and almost insist on it for my own systems. It is starting to appear in more and more mobos, Biostar's TForce have 50 slots? An Asus M2NPV I have has 2 slots. Oh yeah, baby, at least two slots belong on every mobo! Aside from the squealing, and moving on from trying to run stock speed with 1066 ram, the motherboard was a very educational experience to tame. I spent a lot of time digging up and reading all sorts of info on this board, there is a lot more out there on it than the Gigabyte. However, with the Gigabyte I didn't need to dig up any info, what little I would have needed, I already learned from working with the DFI! But seriously, I printed out enough material on the DFI to fill a small 3 ring binder. I think I added maybe 3 sheets to it that were Gigabyte related. The Dark is a little slow to boot, compounded by the double boot, but that is pretty much par for the course in decent mobos -- the cheaper they are, the faster they boot. The bios always fun to work with and plenty responsive on the desktop. Smart Guardian always a friendly face with all the appropriate voltages and info -- Gigabyte's EZTune has one voltage that may be the NB; I have no idea since it isn't labled; and in the BIOS all it tells you for volts is OK... people have been complaining about this for eras, yet they still don't fix it. The P965 chipset being so mainstream, seems very compatible with other diagnostic software. The 650i has been around a while, and Gigabytes entry is a late release, yet Everest can't identify the mobo, and there was one or two other apps that couldn't delve the thing exactly right. The Darks NB heatsink may get a little hot without some active cooling, but nothing like the copper one on the Gigabyte! This big block of black aluminum will never actually burn you. With the Dark I found I had to run way more NB volts than most other owners, and had to add it much earlier. Here she is at 360fsb for 3.2ghz, ram was Buffalo Firestix 6400, at 1080mhz 5-5-5-15 and 2.2V -- the NB is at 1.55 iirc, and reads 1.53 in XP. ![]() This shot quickly taken with the NB at probably 1.65 and reading 1.63, and a toasty 63C -- I cut that back right away, doh! ![]() Here's the Everest screens. The "Unknown" is the Gigabyte heheh, the rest is obvious. Interesting to note the Gigabyte is strong on memory read, but very weak with Photoworx and one or two others. It's the Photoworx test that the Dark at stock speed beat out the overclocked Gigabyte. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________ eVGA 680i SLI (A1) P31 Intel E6750 Conroe 1333 G0 SLA9V L723B134 | Scythe Ninja-B | Antec Tri-Cool 80cfm 2x1024MB Crucial Ballistix Tracer 8500 | 5-5-5-15 1066mhz @1.9v boot: 4x WD Caviar SE16 250gb SATA2 Raid-0 backup: Seagate 500gb 32mb SATA2 eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA juice: PC Power & Cooling 750Quad | Cooler Master HAF932 steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's |
I think you may be interested in this; a memory and BIOS Worksheet for the DFI P965-S Dark! Updated June 24, 2007 Notes:
Clicky for PDF Thumbnail to larger printable 300dpi JPG: ![]() Small 72dpi JPG preview: ![]() Enjoy! :D .
Thanks for the comments, and the worksheet (beats the hell out of the rough hand "drawn" one I was using... :) ). Yeah, I noticed the "warranty only by manufacturer" as well and figured that was the last nail in the coffin for this board. I'm guessing that they just don't get enough stock to be able to both sell it and deal with the squeeling issues. Mine really isn't that bad, like I mentioned in the review I can hear it if I set up my system for lowest noise, but beyond that I don't notice it. I'm getting another board to try out that will verify what the fsb limits of this cpu and mem are, but as it stands the best I'm able to get out of it stable is still pretty well what I listed in the review, and I haven't found the magic mix to get it to play nice with the mem set to 667 which would get me the best ratio for my cpu max.
This has happened with two different sets of mem, and like I mentioned.... at lower OC's it goes away with a slight vcore bump...... Still a lot of playing to be done with this board.... I just got my hands on a tech station and a used E6600 so I figure I'll rip my WC gear out of my case and transfer it all over to the tech station as a test bed and play from there..... :) (getting tired of opening the case to get at the c-mos reset button.... :) ). Has anybody tried the beta bios yet? I know it's got a keyboard c-mos reset setting on it and wonder if it's worth trying...... :)
| Quote:
The playing never really ends, does it? I mean if you did actually get finished with testing and experimenting with every setting and combination, you just swap the cpu and/ram and start over lol. One thing about DFI, it's always a nice bios to work with no matter what the model - genie ftw! Pondering... considering the wall you are hitting, you have nothing to loose by trying new bio's, can always go back if it works out worse. Only real problem is with a new bios it's almost like a new cpu/ram combo, and to give it a chance you sorta have to start over. Either way, it's fun. :D That's why we call is "play" and not work. .
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Please post your DFI P965-S Dark Timings | keenan | CPU's and Motherboards | 8 | August 1, 2007 12:20 PM |
| DFI Infinity P965-S Dark | keenan | CPU's and Motherboards | 10 | July 26, 2007 12:30 PM |
| Another DFI Infinity Dark review by MadShrimps | Babrbarossa | Reviews & Articles from the Web | 1 | May 24, 2007 09:09 AM |
| DFI P965 Infinity Dark review by PCTuner | Babrbarossa | Reviews & Articles from the Web | 1 | May 21, 2007 08:53 AM |
