External mem controller just means no cold bug and more benching fun. :) And if you have questions just ask, chipset straps and mem dividers can be overwhelming until you get used to it.
__________________ Hockey Mod at your service |
| Quote:
You are talking about dropping the multi of the cpu to make sure that it isn't high cpu freq holding it back right????? Or is there a FSB wall that a CPU won't breach no matter what freq it's actually running at?
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
Nice review. I'll be buying this motherboard for $80.00 CAD from another forum. He says it did a 535mhz FSB, and does a 510mhz FSB orthos stable without a problem. It just takes a lot of tweaking.
__________________ [ER] |
| Quote:
Grab it up quick at that price!!!!! :) I think it's a keeper.
| No not freq, each CPU has a FSB wall just like MBs do. You test it buy running the CPU on a board that is proven to have high FSB. I have a P5B Vanilla that does near 600 FSB so when I get a new CPU I throw it in there to see how high it will clock. If it does 540 the the CPU wall is 540. Problem is you need extra hardware to test this, i.e. MB and chip that are proven for high FSB. Otherwise you wont know if the bottleneck is the CPU or MB. Generally, the older CPUs E6600, E6400, E6300 etc have good fsb wall (most >525), the new 4000 series ones suck (can be as low as 420-430), an the 20 versions (like yours) are somewhere in between. That's my experience anyway.
I know this is a n00b quesion...but couldn't you find the max fsb on any mobo by lowering the cpu multi? Or does the max fsb affect the cpu irreguardless of frequency.(hmmm...is that what u were asking Wilson....ok I'm confused lol.)There certainly seems to be a lot more to understanding oc'n on intel
__________________ Amd FX60 @2.9 Asus A8R32-MVP Deluxe 2 Gig Corsair XMS 4000PT 2 Ati X1900's @XTX Speeds 2 WD 160gg HD's in Raid 0 XFi Platinum Tt 680 Watt PSU SATA Plextor DVD (Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's Kandalf |
there are lots of factors that affect how linearly cpus/mobos oc. here is an interesting read ... and there are a few others on that site Secrets of the i965 based Asus P5B and chipset strap uncovered. - The Tech Repository Forums When someone claims stability because it is orthos stable, i always ask have they run smp folding at those clocks. Cuz in my experience with the c2d and especially c2q's, smp folding is the best stress tester for non video intensive use. Well, at least for me it is the only relevant stability test since i build all mine to fold. With presslers, orthos was a pretty good indicator of stability, and still is pretty good with c2d's, but with c2q's it isn't even close (4xp95 is my orthos equivalent for quads). SMP tests more than just cpu and memory ... it is heavy on interprocess communication and cache usage. So i keep a copy of some of the more demanding SMP work units so i can use them to test oc's with. I realize i am somewhat atypical tho, since i use virtually no intense video, and anybody building gaming/video compostion rigs would need to use video stressing tools, possibly in addition to smp like testing. If video is the bottleneck that you oc for, then orthos/4xp95 may be sufficient. Last edited by pscout; June 14, 2007 at 10:57 AM. |
| Quote:
| Quote:
I was working under the assumption that chips without an onboard memory controller would be pretty well "skys the limit" as far as upper FSB was concerned...... Guess I learn something new every day.... :) That said, I guess I'm going to have to get my hands on a board to test out the upper limit of this cpu.... :)
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Please post your DFI P965-S Dark Timings | keenan | CPU's and Motherboards | 8 | August 1, 2007 12:20 PM |
| DFI Infinity P965-S Dark | keenan | CPU's and Motherboards | 10 | July 26, 2007 12:30 PM |
| Another DFI Infinity Dark review by MadShrimps | Babrbarossa | Reviews & Articles from the Web | 1 | May 24, 2007 09:09 AM |
| DFI P965 Infinity Dark review by PCTuner | Babrbarossa | Reviews & Articles from the Web | 1 | May 21, 2007 08:53 AM |
