Old March 12, 2009, 08:50 PM
llama_egg's Avatar
Default Gigabyte EX58-UD5/Exteme able to fit Forte?
Well, not that I'm designing my new build (SSSSH don't tell anyone!), and I've been checking out the EX58-UD5 or more likely the Extreme, but looking at the layout has me worried about it fitting a Auzentech Forte card.
As anyone who has seen the card, while it's small per say, it holds it own when it comes to the length, and I dunno, it's looking like the card just won't fit, which would be quite depressing.
Anywho, anyone able to contribute their 2 cents?
Edit, apparently I'm not looking for a Gigabyte, but a Igabyte! /facepalm
Seriously people, I am not a mod. Stop messaging me D:
Old March 14, 2009, 12:35 AM
llama_egg's Avatar
Juuuust in case, bumping it once, if no one knows, I guess I'll find out when I finally start building
Old March 14, 2009, 12:40 AM
Realityshift's Avatar
If it doesnt fit in the 1x then drop it in that 4x slot just under it. Should work just fine.
The Builders Hammer
Old March 14, 2009, 12:44 AM
Jake_HT's Avatar
Yeah it should fit in that lower slot... how the hell would ANYthing fit in the top slot?
http://jakeht.deviantart.com/
Old March 14, 2009, 03:05 AM
I have no clue, maybe the stock gigabyte sound card solutions they have kicking around fit there, they are pretty short. The other extreme board has one that fits in that spot.
The Builders Hammer
Auzentech X-Fi Forte 7.1 Review NightRain Member Reviews 21 October 15, 2009 02:36 PM
Gigabyte GA-EX58-UD5 X58 Motherboard Review MAC CPU's and Motherboards 15 May 11, 2009 11:28 AM
Problems with ex58 extreme. sheepdogexpress Troubleshooting 5 December 7, 2008 06:04 PM
Auzentech Forte cegras Audio 0 December 5, 2008 12:05 AM
