  #21 (permalink)
Old March 13, 2009, 12:46 PM
CTA's Avatar
CTA CTA is offline
that sucks... but odd..i thought cpu chip is very tight close so no liquid or air will get into... it might not from is alcohol... aka you drop it...
i doubt intel warranty cover it... well good luck
  #22 (permalink)
Old March 13, 2009, 09:04 PM
LCB001's Avatar
Folding Captain
I hope the taxman is good to you, Folding withdrawel is a bi**h, so I'm told anyways...
Folding For Team 54196
  #23 (permalink)
Old March 13, 2009, 09:26 PM
Silvgearx's Avatar
Unhappy
Damn, i hope intel RMA will overlook it
