Old March 3, 2009, 07:55 PM
arekieh's Avatar
Default X3 720BE > X4 :) The Results Thread :)
Alright,
Well the other thread was cluttered with the problems i was having with AMD overdrive. I found a way to monitor my temps and other info. Through the motherboard software. Although i think those cpu temps are a bit off (around 10C off) but thats fine atleast i get an idea of where its at. At stock my cpu was stable for a full 2 hrs with the 4th core unlocked. Right now i just overclocked it to 3.37ghz, currently stress testing, its been 10minutes now and its fine. But well see. That is also with the 4th core unlocked. Screenshots soon :)
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 3, 2009, 09:35 PM
punk_zappa's Avatar
Good for you. I am thinking of getting a 720BE and a Biostar 790GX setup and see if it will unlock for me.
Old March 3, 2009, 10:13 PM
arekieh's Avatar
I got it to 3.5ghz stable for 30 min. just by sliding multi, and bumping voltage + 0.25. Wont have time to play around with it more until this weekend. Probably wont be able to put my componenets in the raven until then either :(. But ill have tons of updates then. Ill update this thread as i get more done
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 3, 2009, 10:55 PM
vinister's Avatar
I got mine to 3.7 in the first couple hours of getting it home, and its been there since. 1.4V, temps are crazy low, never breaking 30C under prime95. This is one madly good cpu. I pricematched it at NCIX for $173, took some convincing but they matched newegg.ca's price in the end.
Cheapest good upgrade ever! Its a huge step up from a 9850BE. I gained some 10-15fps in the games I play. I coudln't be happier for AMD's success and performance.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old March 3, 2009, 11:08 PM
arekieh's Avatar
Ya, even at stock with 3-cores enabled. it feels alot quicker then my e8400. And with the 4th core unlocked at 3.5ghz its wayyy faster
i have to keep pushing it though just no time till the weekend :(
My Trading Rep:
HWC
OCN
Heat
Ebay
720BE and GA-MA790GP-UD4H arrived:) arekieh CPU's and Motherboards 31 March 28, 2009 06:08 PM
x3 720BE drops to $150. upcoast604 CPU's and Motherboards 5 March 2, 2009 07:24 PM
I7 920 OC'ing results so far... rjbarker Overclocking, Tweaking and Benchmarking 18 February 16, 2009 09:05 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 12:52 PM
