Old March 2, 2009, 04:30 PM
arekieh's Avatar
Default 720BE and GA-MA790GP-UD4H arrived:)
My new cpu and mobo just arrived today. and the cpu is... a 0904 :) confirmed to unlock. but ill know for sure in 20min as soon as my files are dont transfering over to my backup :).
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 2, 2009, 04:40 PM
3.0charlie's Avatar
Keep us posted, I just may buy one for my HTPC...
Hydro-Quebec is salivating...
Old March 2, 2009, 04:41 PM
arekieh's Avatar
I bought mine from Direct Canada if that helps at all. Maybe they have more of the 0904. Im about to being installing it right now. Should be done within an hour (reinstalling os and stuff). :)
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 2, 2009, 05:31 PM
Supergrover's Avatar
Mmmmmm unlocked core..........
Old March 2, 2009, 05:51 PM
arekieh's Avatar
gahhh, not used to amd. this bios is loaded with stuff. Gotta get used to it. Reinstalling windows right now. And this bios doesnt show the amount of threads on the boot screen so i cant tell if the 4th core actually did unlock. I put it back to stock, ill try again as soon as windows is up
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 2, 2009, 06:45 PM
arekieh's Avatar
4th Core active. Exam tomorrow so not too much time to do anything. not even enough to install all my programs and stuff. Gonna run Orthos and see how long its stable at stock. Hopefully i got a good core :)
EDIT* OCCT stable for 45min. CPU-Z is showing some really wierd stuff, and speedfan isnt recognizing the temperature of cpu. just says 0. same with coretemp :/
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 2, 2009, 07:53 PM
arekieh's Avatar
WTH, heres what AMD overdrive says:
This is really really wierd
My Trading Rep:
HWC
OCN
Heat
Ebay
Old March 2, 2009, 08:15 PM
sa seba's Avatar
are you using overdrive 2.14 or 2.15?
I had to revert to 2.14, after 2.15 gave me similar weird numbers.
Looks good to me...I'll be joining you with this combo soon.
Old March 2, 2009, 08:16 PM
arekieh's Avatar
2.1.6. ill try 2.1.4 right now.
Its just odd because cpu-z and all the otherp rograms are giving me the same info
My Trading Rep:
HWC
OCN
Heat
Ebay
x3 720BE drops to $150. upcoast604 CPU's and Motherboards 5 March 2, 2009 07:24 PM
Deltas have arrived at NCIX! death_hawk Air Cooling 14 August 26, 2008 12:03 AM
WooHoo it has arrived Beermaster Cases 32 April 17, 2007 09:26 AM
