Originally Posted by TheRock Thank you for your reply.
I will continue using Realtek considering I never removed the RJ-45 at all. I do not need onboard sound so that will be fine. It just bugged me as to why this happened on a reformat and fresh install...:)
Thanks again
TheRock |
Maybe you had the icon hidden before? Easiest way is to just disable the one you don't use. I'd disable it from Device Manager though so that you could re-enable it easily should you ever need it since going into the BIOS is more time consuming.
