Old February 24, 2009, 03:06 PM
WolfBane's Avatar
Default HyperThreading
I have a Xeon 3110 chip (pretty good oc)
Should i enable HyperThreading On my msi board?
Will this show any improvements?
Old February 24, 2009, 03:26 PM
geokilla's Avatar
Isn't the Xeon 3110 the same as a E8400? If it is, enabling HyperThreading won't do anything.
Old February 24, 2009, 03:34 PM
WolfBane's Avatar
yupp i think its pretty much the same as a 8400 justy runs a little cooler:)
Old February 24, 2009, 03:35 PM
WolfBane's Avatar
is that E7200 chip faster than a 8400?
What board do you have? I've only seen 2 diff boards with hyperthreading... old boards that were designed for P4s and the new X58s.
Either way.. Hyperthreading won't do anything as your processor doesn't have it.
Old February 24, 2009, 03:36 PM
WolfBane's Avatar
Msi P35 Neo2:)
Old February 24, 2009, 09:46 PM
SugarJ's Avatar
You can enable it on your mobo, but if your CPU doesn't support it, there will be no effect. IIRC, the last HT enabled chips before the i7 920 were the P4 3.4Ghz CPU's.
Old February 24, 2009, 11:43 PM
1Tanker's Avatar
The P4's(most) had HT right up to the 67x 3.8GHz models.
Hyperthreading Mode (Core i7 920) makes it run hotter appplejack CPU's and Motherboards 4 January 11, 2009 12:44 AM
