Old February 8, 2009, 11:22 AM
Default MotherBoards - Which 2 are best
I have 3 motherboards which 2 are the best to keep
MSI K9N2 SLI Plat
ASUS M2N32 SLI Deluxe
BIOSTAR TA790GX A2+
Thanks any help is greatly appreciated. I'm honestly unsure even after reading some reviews etc which two are best to use for my builds (9850 be, Raptor Drives, Good Video Card 8800GT or better for sure and 1066 OCZ SLI RAM)
Old February 8, 2009, 11:56 AM
"Quote This..."
I think the MSI is the weakest of the bunch.
Old February 8, 2009, 12:06 PM
Digikid's Avatar
I would have to agree.
Old February 8, 2009, 02:21 PM
JD JD is offline
I'd ditch the nForce chipsets.
Get something with an AMD 790 and the SB750 chipsets which would be the Biostar on your list. Though ASUS and Gigabyte have comparable models as well since I'm not a big fan of Biostar.
I'd also consider a Phenom II over the the Phenom 9850BE
Old February 8, 2009, 03:18 PM
geokilla's Avatar
The Biostar would be the best. AMD 790GX chipsets are the way to go for AMD CPUs.
Assuming you're making a new build, don't forget to consider Intel as well. Also, post a thread in the new builds section if you want if you're building a new PC.
Old February 8, 2009, 03:56 PM
Eagle Eye's Avatar
Hopefully you're not into overclocking because the Biostar AFAIK sucks, but it is AM3 capable.
Well the 7xxA never really offered anything better for the AM2 cpu it is AM3 capable with bios update I would imagine, finding information about this board is hard. As for overclocking, couldn't find a decent review.
The M2N32 SLI is a gem, but an antique by todays standards.
Are these components you have already or getting?
Regards,
EE
Old February 8, 2009, 04:16 PM
I already own all 3 but selling 1 for sure. Just wondering which 2 I should keep for the time being until another upgrade! :)
Old February 8, 2009, 04:28 PM
Eagle Eye's Avatar
In all honestly I'd keep the 750a at least you'll have the option to SLI if you get another 8800GT. As for the biostar that would be the one I try to get rid of, the M2N32 SLI is solid board keep it around for a folding box or something.
Regards,
EE
Old February 8, 2009, 05:10 PM
punk_zappa's Avatar
Keep the ASUS and the BIOSTAR.
Old February 8, 2009, 06:32 PM
JD JD is offline
Oh I read this wrong
Well I'd kinda say keep the MSI and Biostar (even though they aren't my favourite brands by any means) just that they are the newest boards chipset wise. However at the same time that ASUS, even though its the old nForce 590, is a very feature rich board.
I'd say keep the Biostar and build a cheap office PC with it since it has onboard video or make a HTPC. If not for you, sell it to somebody you know or something.
Then decide wether you want the ASUS or MSI board to make a gaming rig out of.
Regardless I think you're going to have a hard time selling any of these boards since AMD isn't overly popular and those going Phenom II would most likely rather a higher-end 790GX/FX board that's made for overclocking. IMO I'd just keep them all and when a friend/family member needs a new PC, build them one and sell it that way.
Where's the AM3 Motherboards? CMetaphor CPU's and Motherboards 15 January 15, 2009 02:29 PM
beer n motherboards poots CPU's and Motherboards 11 August 17, 2008 09:21 PM
x58 Motherboards silverchair CPU's and Motherboards 0 August 9, 2008 06:37 PM
FS: AMD CPUs and Motherboards JD Buy/Sell & Trade 10 March 28, 2008 03:47 PM
AM2+ motherboards? sswilson CPU's and Motherboards 7 August 21, 2007 12:17 PM
