Old January 26, 2009, 10:43 PM
mattydies's Avatar
Default Seeking advice - 775 Mobo, hdd's, ram
I want to purchase a new (RELIABLE) Main Board.
I currently have a the hardware listed below (yet to be properly oc'd, all is stock atm since board has been my LARGEST HASSLE / GARBAGE PRODUCT EVER)
1) I do not want to buy another ASUS product again, for a loooooooong time.
2) I wish to upgrade my ram. I wonder about adding more of my current ram
HP2-5300 DDR2 - Mushkin Enhanced
The timings can be tightened up and oc'd a fair bit for super low latency.
Are there any 775 Boards and 6/8 ddr2 slots and overclock-ability? (and also with 8 SATA 2 ports + ESata? Or would I be better of with a SATA sontroller card?). I am mainly a console gamer, but do game on PC occasionally, I like my computer to be quick and responsive, set up for Bluray watching and burning, and running lots of stuff at the same time.
3) I would like to lots of SATA2 slots (2 raptor 74's to be set up raid one), as well as a large storage drive (raid 10). I am unsure if I want to add more 750gb's to my one existing one, or to buy larger drives? I have 2 main concerns - future (raid) (expandability, reliability and speed) and cost.
4) The newest windows I have used is 32bit Windows XP Pro (daily OS, school and home) I have never really used vista (or a 64bit os). I want to try a Windows 7 Beta, 64-bit version. (with my current CPU - E6600) With this in mind, any thoughts?
Thanks in advance, I look forward to stepping back into some something new and neat :)
Matty-D
Old January 27, 2009, 05:10 AM
Babrbarossa's Avatar
NCIX.com - Buy Gigabyte EP45-UD3P ATX LGA775 P45 DDR2 2PCI-E SATA2 RAID HD Sound 2GLAN 1394A CrossFireX Motherboard - GA-EP45-UD3P In Canada. eight sata slots
I wouldn't add more of that 5300 ram unless you can get it up to 1000 speeds with decent timings (you might be able to with that mushkin though)- RAM is too cheap of an upgrade to allow your overclock to be crippled by it.
psst, wanna see my binder?
Old January 28, 2009, 06:36 PM
mattydies's Avatar
WOW, that board seems amazing :D Seems like it will be a GREAT fit for me, thanks again :D
A couple more questions
- Can the board run SLI (It says crossfire, are they different chipsets or something?)
Hmmm I guess that just makes one question.
IT would be interesting to FINALLY try and tune my ram (Tight timings, higher speed & Combination) and at the end, if new ram is desirable, oh darn, time to guy some ram :)
Old January 29, 2009, 12:15 AM
ImmaPC's Avatar
The UD3P CAN NOT SLI. CROSSFIRE ONLY, unfortunately. If you'd like a board that does SLI and overclocks well, you could always check out the EVGA 750i SLI (FTW), or if you are/become ambitious, there's also the 780i SLI which will let you Tri-SLI...
I wouldn't bother adding more RAM and then trying to OC it, you might as well get a DDR2-800/1000/1066 since DDR2 is suddenly dirt cheap. Here Are Some Good DDR2-1000 Or Higher Kits For Your Purusal, If You Wish.
Just as well, I would reccomend you get a new Video card, cos you might want one to go with your new system, like a burger and fries, or cheese and wine, or beer and nachos :D
There's the XFX 4830 - $150, falls in between a 3870 and 4850, significantly better than the 8800/9800GT (8800/9800 are exact same card, but one has Tri-SLI), or if you really like Nvidia you can go with the 9800GT - $130 which is still a very decent card.
A step up from those is the 4850 - $190, gets you significantly more frames than 4830 for $20 more. Then, there's the Nvidia equivalents, the 9800GTX+ - $210, which is actually a bit better than the 4850, but once again for $20 more. This card used to be the 9800GTX but NV did a 55nm refresh and the results were significant. Another step higher, we get the HIS 4870 - $240, which once again has significantly more frames than the 4850 or 9800GTX+. The NV equivalent is the GTX260 C216, which is far better than the 4870, but costs over $300.... :D
Rigless. Secret project in the works.
Old January 30, 2009, 01:06 PM
mattydies's Avatar
Babrbarossa - I think the UDP3 is the board for me.
Thanks a bunch for the recommendations to both (as well as ImmmaPC's links)
I think both these ram kits look pretty darn tempting. 2 of either 4gb kits would be bad ass.
Is that the ram you have in your sig?
Buy Mushkin XP PC2-8000 Redline 4GB 2X2GB DDR2-1000 CL5-5-5-12 240PIN Dual Channel Memory Kit
Canada Computers - Memory > Desktop Memory > DDR2 1066 PC2-8500+ : Mushkin XP2-8500 DDR2-1066 4GB (2x2GB) Extreme Performance Series CAS 5-5-5-15 (996599).
As for the video card, I will stick with my 7800GT for now, but I am pretty sure it will be the next candidate for an upgrade. At that point I will see what suits my needs. Perhaps an ATI (in case I want to make use of the crossfire later on)
Old January 30, 2009, 08:12 PM
ImmaPC's Avatar
I would go for the Redlines, because they are slightly cheaper for a slightly slower speed, by 66mhz. You can easily OC the Redlines to the 1066Mhz that the XP's run at, and keep the CAS timings as well.
Seeking advice on part selection Mibs Water Cooling 26 February 8, 2009 01:52 PM
Seeking advice on new build Gellidius New Builds 8 December 13, 2008 11:08 AM
Seeking advice on multiple soundcard build / Will it work? Ironmonk Troubleshooting 3 December 12, 2008 12:46 PM
Need advice on mobo? bushwickbill CPU's and Motherboards 3 August 5, 2008 03:29 PM
Mobo advice for new build D1rtyB1rd CPU's and Motherboards 26 March 6, 2008 01:23 PM
