<~----> What is your highest q6600 overclock? - Hardware Canucks
Old January 15, 2009, 06:35 PM
derrXIII's Avatar
Default What is your highest q6600 overclock?
Just wondering how high this baby usually will go
i dont think mine is safe :\
im at v1.7 :\
4ghz :\
on air.... :\ :\
Q6600 @ 3.6GHz (400x9) | Biostar i45 | 4850 (700/2010) | G.Skill F2 PC2-8000 @ 800Mhz 2x2GB
Old January 15, 2009, 06:41 PM
Jackquelegs's Avatar
What the heck?
1.7 volts on air should have fried it already, or on its way there.
I'm 1.525v on water, 3.6ghz 400x9.
Iapetos
Zephyranthes
Old January 15, 2009, 06:42 PM
what the?!!!?!!!?!!!!?
Do you have ANY knowledge on proper overclocking?
Old January 15, 2009, 06:44 PM
derrXIII's Avatar
noop :)
is this right? like really, i have air cooling, in a semi-cold room
3ghz @ v1.3 is 16-18 degreez idle. and not even 30 on load
Old January 15, 2009, 06:47 PM
Thats idle.
I dare you to run a Prime95 Small FFT test and watch your temperatures.
DARE
Old January 15, 2009, 06:51 PM
derrXIII's Avatar
i did..
58 degrees for 2 hours
Old January 15, 2009, 06:53 PM
Originally Posted by derrXIII View Post
i did..
What are your ambient temps?
No way your running 1.7v and getting 58 on load with a SmallFFT test unless your room temp is like 5 degrees celsius
Old January 15, 2009, 06:57 PM
derrXIII's Avatar
its 19 right now in my room.
i wish i had a vid cam, id just like upload it and show you :\
when i did it, i started from 3.6 and just went higher and higher. :\ i didnt know that 1.7 was alot cuz my temps were low, so i though it was all good.
you got a cell? i can send you the vid i took, while i did it
Old January 15, 2009, 06:58 PM
You must have some sort of magical Q6600! How are heck are you getting such good temps? Mine's stock speeds with a Xigmatek-S1283 and I can get only get 17 idle if I leave my window open all day, making my ambient ~5 degrees Celsius.
Old January 15, 2009, 07:03 PM
derrXIII's Avatar
LOL! its not magical. my Xigmatek HDT is magic i think. i dont know..
i just need feedback, cuz i thihnk this is kinda crazy. something is wrong... like .. seriously..
My First Overclock Cardboard box with DSL Overclocking, Tweaking and Benchmarking 11 April 11, 2012 05:11 PM
Q6600 overclock to 3.0 GHz HermesĄ˘ RAM 10 November 17, 2008 08:06 PM
ASUS Unleashes Highest Performing Enthusiast Motherboard Lithotech Press Releases & Tech News 46 November 1, 2008 03:38 PM
What is the highest OC you can safly get on the 9800GTX+ SC with the stock heat sink? 49-parallel Overclocking, Tweaking and Benchmarking 0 September 18, 2008 10:36 AM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 04:32 PM
