Old January 15, 2009, 04:59 PM
derrXIII's Avatar
Default Gigabyte p35 problem
Uhm, wut ever i change in my bios for the cpu [e.g., FSB and Voltage] it doesnt change..
i go into my OS and cpu-z doesnt detect a change. is it just the program? or is my bios messing with me. Because my ram timings show that it changed in CPU-Z but nothing for my CPU has changed :\
Q6600 @ 3.6GHz (400x9) | Biostar i45 | 4850 (700/2010) | G.Skill F2 PC2-8000 @ 800Mhz 2x2GB
Old January 15, 2009, 05:20 PM
donimo's Avatar
happened to me, I posted on here I think too, can't remember now how I fixed it either, what bios rev are you running?
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 15, 2009, 05:51 PM
SugarJ's Avatar
That happened to me too. If I recall, to fix it I ended up doing a clear cmos after disconnecting the board from the PSU and taking the battery out.
Old January 15, 2009, 06:43 PM
derrXIII's Avatar
alriught, im gonna try that when i get back to my dorm [left comp at school]
cuz, i cleared my cmos, and the bios was reset, but it was still happening!! :@
thankz
Old January 15, 2009, 07:09 PM
Have you turned off the power saving settings in the BIOS and in Windows?
Anyone used the gigabyte 3D Mars? EaGle1337 Cases 0 November 2, 2008 03:38 PM
Gigabyte watercooling kit Vinnie Water Cooling 1 November 27, 2007 07:18 PM
Gigabyte Poseidon 310 qwerty Rumor Mill 1 November 6, 2007 01:58 PM
Gigabyte P35 is available at NCIX! Misoprostol CPU's and Motherboards 30 June 24, 2007 03:13 PM
Gigabyte GA-945GME-DS2 BALISTX CPU's and Motherboards 1 March 21, 2007 12:51 AM
