Old January 12, 2009, 12:17 PM
SmogTown's Avatar
Default remounting heat-pipe assembly question
I just got an Asus Maximus II Formula and want to remount the heat-pipe assembly but I have one question. Should I use thermal tape to attach the mosfet part of the heat-pipe to the mosfets? I was thinking of just using AC MX-2 grease but I'm not sure if I'll get sufficient contact. Any help would be greatly appreciated.
Intel Q9550
OCZ Vendetta 2
Evga GTX 285
4GB Mushkin DDR2 1066Mhz
2 Seagate Barracuda 7200.11 640GB
Corsair TX750
Coolermaster HAF 932
Old January 12, 2009, 12:22 PM
MpG's Avatar
MpG MpG is offline
I'd use thermal tape, since you'll get more consistent contact. Assuming you could make proper contact on all the chips, the grease would do a better job, but the power circuits on that board are pretty robust, and they're not going to mind an extra degree or two.
Urgent - Do I have Heat Issues? Please look D4ng3r CPU's and Motherboards 8 December 17, 2008 02:14 PM
MSI P45D3 "cinco pipe" flashy cooling Babrbarossa CPU's and Motherboards 5 March 19, 2008 07:22 PM
Heat Issue Lyxtwing Video Cards 8 March 14, 2008 08:35 AM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 06:46 PM
Intel 775 Heat Sink - QUICK question mattydies Water Cooling 3 June 26, 2007 06:57 PM
