Old January 10, 2009, 01:26 AM
Default Hyperthreading Mode (Core i7 920) makes it run hotter
I overclocked the Core i7 920 to 3.94GHZ (turbo enabled).
I ran prime 95 for test and noticed that temperatures in the Core differ when hyperthreading is disabled. The cores run at least 10C cooler. I used Sensor Test, XS Bench in Real Temp 2.90 Beta and found that disabling hyper threading scored slightly better on XS Bench and seemed more stable on Sensor Test.
What do you think?
Thanks.
Old January 10, 2009, 08:46 AM
lowfat's Avatar
Hmm, I might have to try this out.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 10, 2009, 09:27 AM
Babrbarossa's Avatar
Nice going! I'll have to try that if I ever get by rig together
Old January 10, 2009, 07:27 PM
MpG's Avatar
MpG MpG is offline
The temp difference is pretty well documented, I think. The i7 is able to use HT on the priming, which why you should be getting 8 loaded 'cores' in the task manager, hence the increase in temperature. Last I heard, I don't think IBT was able to do that yet, which is why Prime+HT enabled was actually able get slightly higher temps.
Old January 11, 2009, 01:44 AM
burebista's Avatar
Try latest LinX it looks like you should ignore first pass.
Computer Will Post but can't get in any OS MODE v0maru Troubleshooting 10 November 9, 2008 01:02 PM
Does the X3110 run hotter then E8400? Dashock CPU's and Motherboards 36 August 15, 2008 11:14 AM
Sleep & Hibernation mode danger for water pcs? neurobashing Water Cooling 4 November 29, 2007 07:04 PM
X-fi Mode changer app Now compatible with Prelude Robscix Audio 0 November 13, 2007 12:42 PM
synchronous mode on P35-DQ6 vukdusan CPU's and Motherboards 1 August 15, 2007 01:02 PM
