Old May 23, 2007, 07:32 AM
Delavan's Avatar
Default CPU temp or Core temp? E6420 NOOB
Just got it up and running last, night, my first rig, no smoke no sparks!!!
I used PC Wizard 2006 to monitor my stuff.
I disabled the "speed step thingy" in the DS3's bios, and got my Freezer 7 at full blast. I'm just testing and getting used to it.
I get this for temperature (E6420)
Processor temp. 25 deg.cel.
Core 1 temp. 36
Core2 temp 36
Mobo (system) 44
No overclock yet and under PRIME 95 for 4 hours now.
My question is: when you folks OC your C2D's what CPU temp do you consider? Core or Processor?:help:
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Gskill RIPJAWS X / 2 x N560GTX Ti Twin FROZR II OC in SLI (8700 3Dmarks11 P-score)
Old May 23, 2007, 07:38 AM
Patriote's Avatar
On my past system, with watercooling, i used to get 22c - 23c Idle and about 45c - 48c Full Orthos load and that was with my E6600 Oced to 3.6Ggz. I always use Coretemp to monitor temps of my CPU. But sometimes, i use Everest Ultimate because it shows GPUs temps too.
Those temps seems a big high to me with your Freezer 7 at full blast. But maybe it's because of summer and/or thermal compound you used ? Did you put some AS5 or something similar ?
BTW: Enjoy the build m8!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old May 23, 2007, 07:52 AM
Babrbarossa's Avatar
Here's a link to a collection of temp related threads and guides:
EVGA | Message Boards
Generally people say under full load, stay below 65 TCore (Tjunction) and 50 TCase. your 25 is TCase (measured at the chipset), and your 36 is TCore (or Tjunction as some people call it) measured inside the CPU- they're fine.
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old May 23, 2007, 07:57 AM
Delavan's Avatar
Thanks for the reply Patriote and MOD!,
I'm just using the regular issued thermal compound (mx-1 I think) already on the HSF. Arctic documents stated a 200 hours "curing" time ,I suppose I'll gain a tiny bit, maybe one degree.
If you find the temp a little high, well you know better than me.
I got an Armor jR case, with a 120mm exhaust fan right behind the Freezer 7 I supposed it would be a good setup. I'll change that 120 for a TRICOOL ,I'l probably get more airflow than the regular TT case fan. I'm also getting a ANTEC SPOTCOOL to cool RAM/Northbridge and back of 8800 GFX.
Old May 23, 2007, 09:06 AM
Patriote's Avatar
Your welcome
But i doubt that changing the back fan will give anything worth. But yeah, the fan will probably be better than the TT fans...lol
Next time you have to remove your Freezer, clean off the old thermal compound with alcohol or Artic clean, get yourself some AS5 and apply it. You should see a small difference.
• - Noctua NH-D14
Old May 27, 2007, 10:06 AM
Fallen Folder
I have a few af7's and on one of them i tried it with the supplied tim but quickly changed it to as5. I don't recall the temp diff but it was significant ... i was in the process of oc'ing either a 6320 or a x3210 ... can't remember which.
During testing/oc'ing i find that using orthos i am stable till ~ 70C and for stable 724 folding i like to see them no higher than low 60's or erros will happen.
If you have an average 6420, you should be able to run stable at ~ 400 fsb without much voltage bumping with your af7. I have a 6320 folding 724 on a ds3 at 450 fsb.
You may want to add some extra air cooling to the NB once you get the fsb into that range. SB can also get warm dpending on your case. I run all mine caseless.
I use coretemp 0.95 to monitor them in wxp and lm-sensors in linux (it only works on ubuntu 7.04 with the ds3's for me ... haven't tried other distros). Caretemp (and TAT i think) gives you individual core temps ... others i have tried only give a single cpu temp.
on asus mobo's i also run asus probe. I don't find the gigabyte tool very convenient. speedfan may work and seems to be consistent with the linux lm-sersors tool, but both of these consistently give lower quad core temps that coretemp does in windows - just a colibration issue I think, although i don't really trust most speedfan readings.
Old May 27, 2007, 10:14 AM
3.0charlie's Avatar
Core 1 temp. 36
Core2 temp 36
4 hours' worth of Prime and you have 36 Tcore? That's damn good. Apply so AS5 and it will be even better.
Congratz on your first rig!
John
Old May 27, 2007, 02:21 PM
omgwtf's Avatar
CPU:44
Mobo: 43
Core:37 after playing carbon for 2-3 hours...is this good ?
AS5, Arctic Freezer 64 Pro...
Old May 27, 2007, 02:28 PM
sswilson's Avatar
Is that the temp during play, immediately afterwards, or after 5 minutes?
If it's load temps, those are pretty damn good. If they are idle temps it would depend on if you were OC'ing the system.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old May 27, 2007, 02:31 PM
3.0charlie's Avatar
Originally Posted by omgwtf View Post
CPU:44
Mobo: 43
If those are the temps after 2-3 hours of playing Carbon, I would be happy.
Very.
Laptop temp killerklown Mobile Computing 7 March 6, 2008 01:32 AM
E6750 temp help? jasonmoreau CPU's and Motherboards 18 January 23, 2008 04:07 PM
Core Temp Accuracy =/ Yamcha CPU's and Motherboards 5 November 14, 2007 05:35 AM
CPU Temp?? BALISTX CPU's and Motherboards 7 August 22, 2007 03:19 PM
Fan controllers/temp displays Corpus Masochist Water Cooling 9 July 31, 2007 02:00 AM
