Old January 4, 2009, 12:17 PM
Default am2 x2 6000 3.1ghz 65nm?
I have the x2 5600 2MB L2 cache 3ghz sometimes it doesn't overclock much and stay stable. I'm thinking of getting the newer 6000 1MB L2 cache, is there anything in the new 6000 G stepping that would make it better for gaming if both cpus were running at equal ghz?
Thanks.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old January 12, 2009, 12:24 AM
Anything from 6000 and up is really finicky. I would suggest to just wait until AM3 CPUs drop in price after launch and upgrade your system then. If you don't have money to buy new parts try and wait a little for the AM2+ Phenom II
http://www.tbaglan.org/
PC #01
XClio WTBK Advanced
Asus M4A78T-E 790GX
AMD Phenom II X4 970 3.5GHz
4GB DDR3 Kingston HyperX 1333
2x Gigabyte Radeon 6870 1Gb
875W Thermaltake Toughpower
PC #02
Logisys Area 51
Gigabyte GA-MA74GM-S2
AMD Athlon II X2 265 3.3GHz
4GB DDR2
1066 GeIL Black Dragon
Gigabyte Radeon 6850 1Gb
500watt Rosewill PSU
PC #03
Thermaltake SopranoRS
Asus P5N-D
Intel C2D 8400
4GB DDR2 1066 GeIL Black Dragon
Gigabyte Radeon 4850 512Mb
680watt BFG LS Series PSU
Old January 12, 2009, 12:32 AM
Jake_HT's Avatar
I have the 6000+ 90nm version... it's junk really... I only have it to 3.1ghz from 3.0 stock, but my motherboard could also be to blame...
The 65nm version might be better?
Old January 12, 2009, 10:19 AM
Eagle Eye's Avatar
I bought a 5000+ X2 BE 65nm Brisbane core overclocked it 3.2Ghz @ 1.4v just using the multiplier. Jake your cpu probably has a locked multiplier so you'll have to overclock the HTT if you want to see a higher clock, however you don't have much headroom to spare.
EE
Old January 12, 2009, 11:04 AM
CMetaphor's Avatar
Quadfather
Managed to get mine to 3.4 @ 1.58v.... but it wasn't stable at all. Not recommended. Buy a Phenom 2 if you want to overclock .
Old January 12, 2009, 11:17 AM
Eagle Eye's Avatar
That amount of voltage that cpu would die very quickly and temps would of been out of control on air.
Old January 12, 2009, 12:35 PM
I did end up buying the 6000 3.1ghz, after promo code, taxes and free shipping it was $85 to my door (not here yet but soon I guess, it's sitting in Richmond BC). If it's not any better I'll swap it into the wife or kids comp.
I was also looking at a biostar mobo if the price goes down in the next months or so, Newegg.ca - BIOSTAR TFORCE TA790GX3 A2+ AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - AMD Motherboards any comments on that or suggestions on a better board for around the same price $134ish? Thanks again, I probably would get a phenom II when and if the price drops months down the road.
Old January 12, 2009, 01:27 PM
Eagle Eye's Avatar
Judging from the layout of that board any long 2 slot video card will block the 3 sata ports on the board. Personally I'd shy away from Biostar esepcially their lowerend series also this board lacks mosfet cooling just more money to spend on if you intend on overclocking. I'd check out what Asus, Gigbayte or DFI has to offer in that price range if any.
EE
Old January 12, 2009, 02:28 PM
CMetaphor's Avatar
Quadfather
Temperatures weren't an issue actually. As you can see from my Sig... I have what's known as "excessive air cooling" disease .
@Upcoast: Good luck with OCing the newer 6000+! Let us know your results.
The end of 65nm/192 Shader GTX 260's is here! chouchou Video Cards 3 November 18, 2008 06:52 AM
Is my E6400 @3.1Ghz Holding my Gaming Back?! bushwickbill Video Cards 7 May 4, 2008 07:23 PM
VR-Zone overclocks 2900xt Core to 1GHz!! Babrbarossa Reviews & Articles from the Web 0 May 16, 2007 02:17 PM
ATi 65nm RV610/RV630 Cards Info Supergrover Rumor Mill 0 February 11, 2007 10:40 AM
bit-tech reviews Athlon 64 5000+ 65nm Supergrover Reviews & Articles from the Web 4 January 19, 2007 03:40 PM
