Old December 28, 2008, 01:35 PM
andynerd's Avatar
Default (solved) could i burn out my mobo by....?
Could I burn out my mobo by:
Turning it on but forgeting to plug in the cpu power cable?
Forgetting to plug in the cmos jumper and turning it on?
My computer keeps crashing on the boot, I assume it may be a power issue ont eh mobo because everytime it crashes closer and closer to when i hit the power button. If i turn off the computer and the power supply and then turn it back on after a while it starts loading almost all the bios agin and then crashing
"let the geek be with you"
Specs: Asus G74SX
Old December 28, 2008, 01:59 PM
It might be a good idea to post your full specs - motherboard, power supply brand and rating, graphics card, RAM, how many sticks, etc.
What do you see on your screen, do you see something, does it post or do you see a black screen - when you say it "crashes" do you mean it turns back off or locks up ?
Do you hear any beeps?
If you have more than 1 stick of RAM, try removing the others and run with only 1 then turn on your system..... That can be a RAM issue / timing - if I understand correctly you tried resetting your CMOS right ? Try swapping sticks and see if it helps.
Old December 28, 2008, 02:12 PM
andynerd's Avatar
The board is an asus P5Pe-VM there are two sticks of 1 gb ram when the computer crashes it actually just turns right off. It is also makes a electric hum the same electric hum it makes when it is turning off. It also makes a clicking noise when it turns off.
The cpu is a pentium D at 3.4ghz a core. The hard drive is a sata one and the psu is a 450W power supply aside from that i don't know anything else about it.
Specs: Asus G74SX
Old December 28, 2008, 02:22 PM
andynerd's Avatar
I have another symptom when my computer turns on there is no signal from the VGA (it only did that when i forgot to plug in the cpu power cable but it was pluged in!)
Could my power supply be failing?
Specs: Asus G74SX
Old December 28, 2008, 03:17 PM
andynerd's Avatar
Confirmed that it was the power supply it burned out, i noticed because it started smoking and making sparking sounds!
Specs: Asus G74SX
Old December 28, 2008, 04:12 PM
belgolas's Avatar
oh that sucks. Hopefully the power supply didn't take any other parts with it!
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old December 28, 2008, 04:22 PM
It was probably a generic, poor quality PSU and not providing enough power to your components particularly the CPU / graphics card (not enough amperage) OR simply bad PSU - but your humming and clicking sounds was a giveaway -
Old December 28, 2008, 09:56 PM
andynerd's Avatar
the psu was an iso-500
Specs: Asus G74SX
Old December 28, 2008, 10:06 PM
chrisk's Avatar
Folding Captain
Holy multi-threads Batman...this guys has more threads than Spiderman...I was just thinking 'didn't I just post in here' but it was another thread.
Trying to help you guy you should just keep the one thread going mate to make it easier
Fold for team #54196
Old December 28, 2008, 10:29 PM
andynerd's Avatar
closing thread
Specs: Asus G74SX
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
FS: Retail e6600 ---- DFI 975X Mobo ----- Logitech X-530 ------ LF: Phenom Mobo thatguy Buy/Sell & Trade 15 May 1, 2008 09:38 PM
Can shorting a mobo, on the case, ruin that said mobo? mattlef CPU's and Motherboards 25 April 23, 2008 03:00 PM
Burn time enzeo Storage 3 July 24, 2007 11:13 PM
CPU Burn-in time Bognostraglum Troubleshooting 7 April 28, 2007 08:25 AM
