Old December 25, 2008, 12:12 PM
andynerd's Avatar
Default Power problems
Everything on my motherboard works except the ethernet. The motherboard is an asus P5PE-VM. The ethernet worked for maybe an hour after I turned it on this morning but after a restart it stoped!? The light was also on to show the ethernet cable was plugged in but now it doesn't even show up. I am just going to assume this is a power issue. (The power supply is a 450W)
"let the geek be with you"
Specs: Asus G74SX
Old December 25, 2008, 12:16 PM
sswilson's Avatar
Check your power saving features in OS / Device Manager. Make sure it's not set up to "allow OS to put this device to sleep for power saving".
Old December 25, 2008, 12:19 PM
andynerd's Avatar
The device doesn't even show up in the device manager. I tried long and hard to make it show up but it just won't.
Specs: Asus G74SX
Old December 25, 2008, 12:27 PM
sswilson's Avatar
If it's not even showing up as an "unknown device" then all you can do is check your bios settings to ensure it's enabled and if that doesn't do it I'd suspect the board is toast. Try a C-Mos reset just to be sure........
Old December 25, 2008, 12:47 PM
andynerd's Avatar
I still wonder though why it didn't work, then worked after being off for a few hours, then didn't work again.
Yes I did reset the Cmos no help probably is fried.
Specs: Asus G74SX
Power a fan with a floppy power cable? andynerd Air Cooling 4 December 26, 2008 12:50 AM
Big Problems Feff Troubleshooting 9 January 23, 2008 03:24 PM
