<~----> installing a motherboard - Hardware Canucks
Old December 17, 2008, 05:34 AM
Defiant's Avatar
Default installing a motherboard
okay so i have been installing my motherboard and im short on screw and one washer. So my question is ... is it okay with one mounting bracket not to have a screw in or should i take the mobo out and remove the extra bracket?
Old December 17, 2008, 05:39 AM
sswilson's Avatar
I'm not completely sure what bracket you are talking about..... Do you mean the stand-offs that raise the motherboard off of the tray?
If so, as long as the stand-off is in the proper location for a screw you should be ok, but you really should try to track down another screw. The key here is to ensure that all of the stand-offs line up with a screwhole on the motherboard... if they don't you risk shorting out one of the traces/solder points on the bottom of the motherboard.
Old December 17, 2008, 05:45 AM
Defiant's Avatar
thats what i mean the standoff. yeah it does line up perfectly. im pretty sure i can find another screw but do i need a washer or is it okay as long as its not touching the pbc or soldering on the motherboard
Old December 17, 2008, 05:51 AM
sswilson's Avatar
Unless you're using a verrrryyyyy old motherboard you don't need washers at all. If you look at your motherboard chances are you'll see a metal ring around the screw hole which (to the best of my knowledge) grounds the motherboard to your case through the screw.
Exmortis's Avatar
It depends which standoff, is it close to another so theboard is still supported? Or is it all out by itself. I would remove the stand off if it is metal, if I though it wouldnt weaken the board too much. A short is bad news. Usually you can find another screw that fits in the slot. Some of your mounting screws for other hardware will fit, do not force a thread that doesn't fit or use a screw that will not tighten.
Good luck!
Exmortis's System
Corsair 600T White
Asus P8Z68 Deluxe /Gen3
Intel i7-2600K w/Corsair H100
8GB Gskill DDR31600 cl7
MSI Lightning HD797 Lighting
OCZ Revo 3 240GB
OZC Vertex 3 240GB
WD Velocirapter 600GB
LG DVD burner
LG BluRay Burner
Sound Blaster XFi Titanium PCIe
Windows 7x64 Prem
Asus VE24/VE27/VE24
Logitech Z-5450 5.1 speakers
Corsair AX850 Gold PSU
Corsair K90 Keyboard
Logitech G5 Mouse
Old December 17, 2008, 06:03 AM
Defiant's Avatar
yes my mobo does have the metal rings around the holes i was just wondering because i got washers with my bag of screws.
Old December 17, 2008, 06:06 AM
sswilson's Avatar
IMO, all that using washers to secure your motherboard does is increase the chance that you're going to drop one and it's going to end up shorting something out inside your case. :)
Old December 17, 2008, 10:29 AM
I would recommend properly securing your entire motherboard to the 9 holes, that's why they are there - so that when you remove a card from a slot or other that the board stays tightly secured to the case and not warp/bend - and no you do not need the washer anymore - just make sure the motherboard is properly secured but do not over tight the screws.
Old December 17, 2008, 12:38 PM
3 of 7's Avatar
Try stealing a mounting screw from your HD, if it's a fine thread standoff try one from your cd.. They'll both be fine with three screws.
If you live anywhere near Nanaimo I'll give you a pocketfull.
help installing heatsink Zippoh Air Cooling 26 December 9, 2008 08:36 PM
Question on installing OCZ Vendetta tao5269 Air Cooling 4 May 1, 2008 07:07 AM
Installing 3rd Boot with VISTA 64 francois methot O/S's, Drivers & General Software 1 May 31, 2007 02:15 PM
Installing faster RAM on BAD AXE2 francois methot Overclocking, Tweaking and Benchmarking 12 May 13, 2007 02:55 PM
Dell installing Linux! Babrbarossa O/S's, Drivers & General Software 0 March 29, 2007 11:52 AM
