Old November 24, 2008, 09:17 PM
Default Asus mother board with eatx12v help please
Hello,
I'm building my first PC and have a question..
I ordered a ASUS P5Q LGA 775 Intel P45 ATX Intel Motherboard
as well as a
Thermaltake W0070RUC TR2 Series 430W Power Supply.
I have the same mother board in another machine as I wanted to order the same so I
had a reference to go by.
Today I got my PS and Case. I noticed that the PS unit that I got has no "EATX12V" on it. I'm not sure what this is so maybe you guys could help me out.
Someone said this was if I wanted to run a high end PCI express graf card. If not then I would leave the cap on this and use the 4pin 12 V plug there.
Any ideas. I attached an image of the mother board and links below to the hardware.
This is the same mother board I have but mine does not have the liquid cool.
newegg Product/Product.aspx?Item=N82E16813131295
newegg Product/Product.aspx?Item=N82E16817153023
Thank you
Sean
Old November 24, 2008, 09:24 PM
I highly recommend you use this as it will provide better and more stable voltage to your board for all functions.
If your PSU lacks one save up some pennies for a new PSU.
Old November 24, 2008, 09:34 PM
Default Hello Thanx
Hello,
Could you recommend one for me..
I have around 50-75.00 to spend ?
Any ideas ?
Thank you
Old November 24, 2008, 09:36 PM
Well check yours first.. it'll be referred to as EPS 12v and is usually 4+4
Old November 24, 2008, 09:40 PM
Default Hey
Hey,
Only has one 4 pin 12V connection.. No EPS 12V
Thanx
Old November 24, 2008, 09:45 PM
Eagle Eye's Avatar
Mpis welcome to the forums!!
If could tell me where you will be purchasing your PSU I might be able to offer you suggestions from their current line that is within your budget.
Many thanks,
EE
Old November 24, 2008, 09:52 PM
Default Hi
Hello Eagle.
First thank you for your help..
Right now I'm using Amazon...
And also I have a Antec P182 Advanced Super Case which seems to have little room for a large power supply.. I guess there are diff sized power supplies ? ??
Any help would be great and appreciated..
thank you
Old November 24, 2008, 10:31 PM
Eagle Eye's Avatar
I agree the P182 does have issues with larger PSUs currently I have Antec TPQ 850 and its an extremely tight squeeze.
Suggestions:
Amazon.com: Antec NEOHE 550 High Efficiency 550W Power Supply Unit: Computers & PC Hardware
Have you considered purchasing from any other e-tailers, I imagine you are currently in the U.S.A.?
I'd suggest giving www.newegg.com a try much better selection and prices are reasonably competitive.
Regards,
EE
Old November 24, 2008, 10:53 PM
Hello,
Just check this out..
It says 2 x 12V (P4)
Is that the EATX12V that I need?
Seems I would use both of those to hook into the mother board right ?
Ready to order :)
Thank you
Old November 24, 2008, 11:40 PM
Eagle Eye's Avatar
Correct this PSU has the 8 Pin 12v connection you need.
Oh and I saw the board that you got from Asus and my goodness that is worst placement of any 24pin ATX power connection I have ever seen, what was Asus thinking!
