Old November 22, 2008, 08:40 PM
Default Asus P5Q Pro And Corsair 750W
I changed my PSU on this system.
Cpu E6750
Ram OCZ 1150 (not actually at 1150 now)
Corsair 750w
Raptor 74g
Nvidia Quadro PCI-E
System is being very unstable, could it be my power supply. I was using my OCZ before this PSU.
Thank you
Old November 22, 2008, 08:45 PM
Neolithium_Wpg's Avatar
What was the OCZ Wattage? And you mention your RAM isn't at 1150 now either, did some bios settings change that could have caused the instability?
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old November 22, 2008, 08:52 PM
PSU won't make a difference.
But perhaps you have instability in other areas.
I suggest running Memtest.
Chilly's Avatar
Cpu E6750
Corsair 750w
Raptor 74g
Nvidia Quadro PCI-E
Thank you
Unless the PSU is defective, the Corsair 750w is of higher quality than any PSU OCZ sells. Really we need more info, what did you change, how is it unstable, BSOD's, no post, etc. If its BSOD what error messages is it throwing up, etc. I need more cowbe.... I mean information!
Old November 22, 2008, 08:59 PM
The OCZ was 650watt. Nothing changed, no overclocking ram is set at auto. Everything running stock. Before system was stable with a cheap psu 450watt.
Memtest passes. The system freezes, crashes alot. Even with fresh windows install.
Thank you
Old November 22, 2008, 09:00 PM
How long did you let memtest run?
Old November 22, 2008, 09:03 PM
I let it for 2 tests, but last time test for 24 hours straight passed at 1200 and 2.1v.
Thank you
Old November 23, 2008, 01:50 AM
Dashock's Avatar
Hey elec999 if yu are still having problems Ket over at xtreme forums has made a lot of special bios mods for ours boards so let me know ill send yea the link im using his 1306 right now very good overclock and stability is exxelent.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old November 23, 2008, 01:59 AM
This is unnecessary.
He has a hardware problem somewhere he needs to figure out.. and perhaps its something as simple as supplying proper voltage to his memory.
Old November 23, 2008, 05:10 PM
Modded 1501 bios looks promising, but I dont think it will solve my issue. I got no clue what happened, all the system are the same as before. Only made change was the power supply.
Thank you
