Old May 9, 2007, 12:14 PM
CMetaphor's Avatar
Quadfather
Default AMD Readyboost?
Does it work? Is it worthwhile always having a flash mem. stick plugged into your comp?
For those that dont know what im talking about, AMD Readyboost is the technology that allows newer AMD processors to use a removeable (flash) drive as part of its ram (if i understand it all correctly) for improved speeds surpassing even raid 0 speeds....
Has anyone tried it/ tested it/ benchmarked it? etc...
If not... then I shall be the first (Since im going to be reviewing my whole system and posting the build for it as well).
Old May 9, 2007, 12:34 PM
Deathspawner's Avatar
I am not sure how it could be faster than RAID. Most good RAID setups can push like 150MB/s, while memory bandwidth is over 6,000MB/s. Flash drives top out at 38MB (theoretical max speed of USB 2.0).
If there are any differences at all, I'd be impressed. Like Vistas ReadyBoost, I am sure it will benefit low-end PC's more than anything.
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
