  #21 (permalink)
Old November 23, 2008, 09:45 PM
muse108dc's Avatar
it might be a good idea for AMD to leave some headroom but you really have to wonder why would they release them clocked so lowly if they can hit 4ghz on air. Ofcourse you could ask the same for Intel.
Well, heres to hoping AMD has got itself back on track
  #22 (permalink)
Old November 24, 2008, 01:18 PM
khelben1979's Avatar
I'm very interested in the AMD Deneb core architecture as well. Will be interesting to see some figures once they arrive. From what I have understood they require less power than the current Phenom chips which is more than positive.
My future computer system will consume less power than my current system is the plan. And at the same time I'm after great cpu and graphics performance.
Looking forward on seeing the Phenom II in action.
  #23 (permalink)
Old November 24, 2008, 01:58 PM
S_G's Avatar
S_G S_G is offline
Wow, I might have to go AMD to check these puppies out. If only for the overclocking madness!
Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water (Goodbye, Skulltrail.)
Rocketfish LL case painted black // PCP&C Silencer 750W
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro (HD380Pro soon)
HTPC: E1200@3.2 + IP35 + 4GB DDR2-800 + HD4850 + Silverstone Kublai KL02
Router (WIP): Intel Atom 230 + Intel PRO/1000 GT + GS108T gigE switch + WRT54GL + a drawer
  #24 (permalink)
Old November 24, 2008, 03:15 PM
Hopefully its not all about the overclocking and their cpus will compete with at least the c2d's clock for clock. Dont feel like having a 3ghz quad that i have to oc to 4ghz just to match a 3ghz c2d :\ If they can pull that off i may just go amd on my build, depending on the cost of these things.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
  #25 (permalink)
Old November 24, 2008, 06:33 PM
sswilson's Avatar
What about a 3G quad you could overclock to 4.5G that would match the best performance you could get out of a 3G intel clocked to 3.8G? If they can pull that off at a decent price point, I'm in. :)
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #26 (permalink)
Old November 24, 2008, 06:59 PM
kirk_d's Avatar
Don't look to AMD for power saving if you like overclocking.
I have a 90 Nm 170 Opty, 3 year old technology.
It sucks 200 watts at full load
Thank God it's under water! (Thank God My Mobo can take it)
Now a 140 watt or 125 watt Phenom 2 is gonna suck WHAT OMFG at 3.95 Ghz
It's gonna SUCK A LOT! I can hardly wait.
Although I guess if you enable C&Q and run stock, everything should be fine.
Opty 170(naked) @2600 | Abit AT8 32x | EVGA Vanilla 8800gt 650/1625/950 | 2gb Ocz Pc4000Eb@260 | Audigy Gamer | Tx650 | Cm690 |
WC Loop: DD Cpx-Pro | HWL 240 Xtreme | D-Tek V2
  #27 (permalink)
Old November 24, 2008, 07:01 PM
encorp's Avatar
I don't really find this to be that exciting; there are reports of i7's hitting similar mhz all around. Until I see one, running at those speeds in my hand I won't really give it any weight. Not to mention; AMD yet again trying to stab at generations old technology.
When they move away from ZIF, I'll start to take their endeavors more seriously. Just my 2 cents! haha
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
  #28 (permalink)
Old November 24, 2008, 07:48 PM
kirk_d's Avatar
Originally Posted by encorp View Post
I don't really find this to be that exciting!
I think it's exciting!
  #29 (permalink)
Old November 25, 2008, 05:20 AM
Regarding low power consumption with the Phenom II: I believe they will do the same as they have done with the current Phenom chips, releasing slower models which consumes more than half of the most powerful Phenom chips.
When it comes to performance, I'm excited to get more fps in Spellforce 1 (from JoWood). It's a bit slow on my five year old Pentium 4 processor over here. It's a pretty cpu intensive game with a slow 3D engine.
Spellforce was released in 2003 and if I could play the game in 1024x768 with great performance I would be more than satisfied.
  #30 (permalink)
Old November 25, 2008, 05:28 AM
mailaw's Avatar
You could just get a current Core 2 and half-decent video card and you would be more than satisfied if that is your requirements.
