Old October 30, 2008, 02:00 PM
Default new build need info
Hello,im going for e8400 duo and was wondering whats the best mobo for around 150-160$ can.I was looking for either the gigabyte p45 ds3l or ds3r,dont know witch or is there something better for that price range.
Also is the difference with those two mobo only in the crossfire for the ds3r.
Thanks
Old October 30, 2008, 02:39 PM
Asus P5Q's seem to be popular too and they're in that price range.
Old October 30, 2008, 03:11 PM
Leclerc's Avatar
Gigabyte are great motherboards ... personnally i'll go with the DS3R if you would like to keep the option to get crossfire ... if you plan to buy a nvidia base card or will never do crossfire the DS3L is almost the same board ... without the second pcie x16 slot.
Leclerc
AthlonX2 4600+ @ 3.0Ghz (tweaked by Ebdoradz) | Gigabyte MA790X-DS4 | 2x1GB Mushkin HP PC2-6400 @ 860Mhz | Silverstone Strider 500W PSU | Palit Radeon HD 3850 @ 720Mhz/1.76Ghz on 22" Acer X223w monitor | Thermaltake SopranoRS 101 | 1 x Seagate 250GB
Old October 30, 2008, 06:10 PM
Thanks for the quick replys,so the only difference between the ds3l and ds3r is the second slot for crossfire, do you think it will overclock the same as the ds3r because im not thinking of going crossfire .
Thanks
Old October 30, 2008, 06:23 PM
BALISTX's Avatar
Yes it will overclock the exact same as it is the exact same chipset.
Heatware
HWBOT
Old October 30, 2008, 06:24 PM
3.0charlie's Avatar
The DS3R also has on-board RAID.
Hydro-Quebec is salivating...
Old October 30, 2008, 06:43 PM
Is it a good match with e8400duo or should i get the asus.
Thanks
Old October 30, 2008, 06:50 PM
3.0charlie's Avatar
Of couse it is, just like the P5Q is a good choice too. It mostly comes down to brand preference.
