<~----> Swapping out CPU's - Question - Page 2 - Hardware Canucks
Old October 30, 2008, 01:35 PM
Originally Posted by rjbarker View Post
Jay...how'd that 8800GTX work out for you anyways!?
working great ,its the gpu im using atm with a 37" lcd... no more sli ,ill put 1 in each pc.
card runs cool on box(open air) have not tried it in a case yet ... gotta get back to fin my builds soon.
then try to OC this 8400 also.
im very happy with it,
thanks again :)
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old October 31, 2008, 11:18 PM
rjbarker's Avatar
Glad to hear it Jay....you'll be already now to "batten down the hatches" in preperation of your Sask winter!
Old October 31, 2008, 11:19 PM
rjbarker's Avatar
Hey...remember you were telling me about that OCZ SLI Memory ??..do you still have it?
Old November 1, 2008, 10:13 AM
sure do bud, 2 sets 2x1gb 8500@1066,i be willing to let a set go,if you in need...
give me a call or drop me a pm ,im sure we can work something out
edit:i also acquired a of set of OCZ DDR2-1150/PC2-9200 ,how fast you want to go? :)
maybe i can get settings from you to OC my E8400/780i when you find your max OC
Old November 1, 2008, 11:08 AM
Linus's Avatar
FYI if you swap CPUs in Vista you will have to reformat to make your TV tuner work again (if you have one). I learned this the hard way some time ago :(
Old November 1, 2008, 11:18 AM
Supergrover's Avatar
Wicked, thanks Linus
Since I didnt know this and have a TVtuner on the way, and wanted to see if the 9950 would net me any realworld gains in my HTPC project.
R.I.P.
Old November 1, 2008, 11:22 AM
sswilson's Avatar
Might as well jump in with a somewhat related question since the thread is kinda leaning in that direction......
How have the enthusiasts amongst us found Vista's behaviour to frequent hardware changes? One of the reasons I was originally opposed to upgrading from XP was the concern that folks who change hardware frequently would find themselves SOL after a certain # of hardware changes. Was that concern valid? Does anybody (with a legit Vista license) have first hand experience with the process or is everybody on Vista who changes hardware frequently running some form of "patch" which does an end-run around the issue? (No discussion on the actual "end-run" please... :) ).
Old November 1, 2008, 11:33 AM
The only problem that I have had has been when my mobo blew a cap, since it is a OEM copy I had to call MS.
I have changed everything from CPU's to hdd's and that was the firstime I had a problem.
R.I.P.
  #19 (permalink)
Old November 1, 2008, 11:39 AM
sswilson's Avatar
No issues with M$ getting it activated on a new motherboard then?
This is an important issue for me as I've been through at least 8 different CPUs and 6+ different chipset motherboards with each of my current XP licenses (OEM). I've also been through Socket A, S754, S939, & S775 without having any issues other than the need to call them to confirm that it's only installed on one computer.
  #20 (permalink)
Old November 1, 2008, 11:47 AM
Yes and No they didn't want to do it but I bitched that the mobo died and since it wasn't covered by warranty no RMA was available. It took about a hour of jaw-jacking to someone that I could barely understand ( harsh accent) to drive that home but in the end I got a new Key.
R.I.P.
