Old December 15, 2006, 10:20 AM
Babrbarossa's Avatar
Default Help! old floppy compatible???
pant, pant, Hi!-- pant, pant, pant....new computer here-- yippee! Need to flash new bios......need floppy....found 10 year old one.....worry about compatability....help....hurry..:D
psst, wanna see my binder?
Old December 15, 2006, 11:10 AM
sswilson's Avatar
A 10 year old floppy drive is probably a standard one. (I'd guess going back to early 90's for earlier versions).
What mobo are you flashing??? Did you check the website to see if they have a bios flash cd available?
If not, I'd suggest looking into making a bootable cd to run it off of. Winflash is a no-no, floppy flash is better (only if you have a ram disk you can copy the flash program & bios file to), but bootable cd or usb key is the safest.
Old December 15, 2006, 10:02 PM
Gav's Avatar
Gav Gav is offline
Administrator
Glad to hear your computer finally arrived.:D
10 years old hmm.... I think it should be ok. See if it says 1.44 stamped on it anywhere. If so it will work fine. Good luck and if you need more help let us know.
Old December 15, 2006, 10:12 PM
UNESCO's Avatar
i don't even know where my floppy went, I bought one but it's in a box somewhere now that motherboards have SATA driver support
Old December 16, 2006, 07:34 AM
yeah 10 years...I think I will try it tommorrow though.. Anyway, I overlcoked the fsb anyway with the original bios-- have a look at the other thread i started and tell me what you think of the results.
Old December 16, 2006, 06:33 PM
Gav's Avatar
Gav Gav is offline
Administrator
I'll always have a FDD lieing around the house and i'll continue to do so until all new MB's can flash from CD or USB key. You can get a FDD for $10.00 so why not.:)
Old December 16, 2006, 11:34 PM
sswilson's Avatar
Have you flashed yet????
General rule of thumb for bios flashing is "if it ain't broke..... don't fix it!!!"
Of all the things you can do to your system, flashing the bios is probably the most dangerous, and is only recommended if there is something in the update that you need.
Old December 16, 2006, 11:58 PM
Thanks for reassuring me on that- I was thinking I would skip it since things seemed to be going pretty good with it.
F6 floppy driver ACER Aspire 360? francois methot O/S's, Drivers & General Software 1 April 5, 2008 03:56 AM
What aftermarket coolers are compatible with 8x00series? AERo Water Cooling 5 December 18, 2007 12:26 PM
X-fi Mode changer app Now compatible with Prelude Robscix Audio 0 November 13, 2007 11:42 AM
Striker Extreme/ compatible memory? wpurcell CPU's and Motherboards 2 August 23, 2007 01:41 AM
Will my mobo be compatible? Shiverwarp RAM 1 July 19, 2007 04:14 AM
