Old October 23, 2008, 11:34 AM
Default Q9550 Temps
Hey all, just built my new system up. Specs as follows:
CPU: Intel Core 2 Quad Q9550.
CPU Cooler: Thermalright Ultra 120 Extreme with Antec Tricool 120mm fan.
Motherboard: Asus P5Q Pro.
Graphics: Xpertvision Radeon HD4870 1GB.
RAM: 4GB Corsair Dominator Twin2X PC2-8500.
HDD: Samsung Spinpoint F1 750GB.
DVD Drive: Samsung SH-S223Q 22X SATA Lightscribe Dual layer DVD±RW Writer Black - OEM.
PSU: PCP&C Silencer Quad 750w.
Case: Antec 1200.
OS: Vista Home Premium 64bit OEM.
I hope to OC this rig soon but just wanted to check in about the CPU temps to make sure everything is alright before I start.
I'm using Real Temp 2.70 to get the temps and Prime 95 v25.6 to load the cores. So far I've had it running the Small FFTs (4 threads) for about 45 mins and the max temps as reported across the cores are: 46/44/42/46.
Please let me know if these temps are acceptable as I'm a total noob to OCing and don't want to risk going ahead before I make sure everything is alright at stock speeds.
Old October 23, 2008, 11:50 AM
3.0charlie's Avatar
Looking good, don't go over 65C, 1.4v vCore, 1.4v VTT (vFSB).
Hydro-Quebec is salivating...
Old October 23, 2008, 11:59 AM
FrankyG's Avatar
I have a Q9550 @ 4Ghz right now stable temps peak at around 50 full load but that on water. The Q9550 as alot of potential I am sure you can bring it to 3.4 ~ 3.6 on air with no voltage change.
Intel i7-5820K, MSI X99 SLI Plus, 16GB DDR4, Geforce GTX980
Old April 16, 2009, 06:37 PM
Delavan's Avatar
I'm just figuring everything out about my Q9550 before I start OCing...
Using realtemps 3.00 I get a weird result...39-37-32-32...don't know if it's normal of not.
Seems like there is a few people that experience the same issue...
Does it looks like a "reseating job"???
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old April 16, 2009, 06:56 PM
Delavan's Avatar
Lots of people are given the advice to reseat, and it doesn't change a thing...so Quad owned, please advice!
Old April 16, 2009, 07:00 PM
3.0charlie's Avatar
This delta in temps happens. Yes a reseat may fix it. Sometimes loading the chips evens the temps across all 4 cores.
Old April 16, 2009, 07:31 PM
MajorBuzzon's Avatar
My Q9450 had a bad sensor in core one,on 60 all the time.So i just got my RMA Q9450 from intel and getting almost same Temps as you,getting 34,33,37,37 at idle OC to3.6 on air
Old April 17, 2009, 03:39 AM
Delavan's Avatar
Now, I'm still at stock clock ,encoding a video, and my temps are the following:
48-37-37-40...core zero seems a little off...but core 1 is fine.
As core 0 & 1 are on the same die, you'd think they should run at the same temp?
In task manager, at those temps, I get
core 0 = close to max cpu usage
core 1 = close to max cpu usage (same a 0)
core 2 = 30% load
core 3 = 75% load
so 0 and 1 got the same load, although there is a 12 degrees Celsius discrepancy betwen both cores...
Old April 17, 2009, 01:47 PM
Delavan's Avatar
Ok,
I tried a little OC just for kicks...HSF's fan at 2000 RPM, 1.3Vcore, 400FSB (3.4GHZ)
I'm running one instance of prime95 (small tff) and one of OCCT CPU test.
The temps are the following:
0=58
1=47
2=53
3=52
???I assume cores 0 & 1 are on the same dual-core die...but jeez the temps are weird.
Old April 17, 2009, 01:59 PM
I have a 9450 with the same "problem" - and have tried EVERYTHING to solve it.
Until I heard this little tidbit. Apparently the L caches - or the memory controller for them - (shared cache.. L3 if I remember) are closest to core 0 on the Yorkfield dies and as a result cause it to run hotter. If it makes you feel any better, the hotter it gets, the less the cache temp seems to affect things. Temps are all even by about 65-67C.
I have managed to get my 9450 to hit the thermal limits only once, while I was testing the stock HSF with a minor OC in P95. It was actually core2 that thermalled first (according to realtemp)
Bottom line, IMO, don't worry about it. Lots of people have the same delta in temperatures, lots have tried, no one seems overly bothered. The reality of it is that even if core0 is consistently in the high 50s/low 60s, you're not going to burn it out before you want to upgrade anyway.
