Old April 19, 2009, 02:12 PM
Delavan's Avatar
Well,
Now that I cranked up the FSB speed and added a little voltage, everything seems a little better.
450FSB
1.31 VCore
Fsb Termination 1.26
NB Volts 1.26
SB Volts 1.10
PCIE SATA Volts 1.50
Idle: 40-37-35-35
Load (prime95) 58-53-59-59
Core 1 seems to be a loner...lol
I'll let it run overnight...
How does it look?
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old April 19, 2009, 03:50 PM
My Q9450 does the same thing. At 40-50C I almost have a 10C spread. Apparently the sensors are calibrated to be accurate at the throttling point and will be less accurate the cooler the chip runs. My chip seems stable and I can get 3.2 rock solid out of it on my crappy mATX board with no voltage boost. My board seems to be FSB limited in the 420-430range (same limit with my e8400)
Old April 19, 2009, 07:30 PM
Temps look normal.
Old April 19, 2009, 07:55 PM
I get about the same temps with my Q9450 as well.
under Prime95 load at 3.45 ghz 1.3v I get
58, 58, 54, 54
at 3.6 Ghz I get up to 61 degress on core 0 and 1
Old April 20, 2009, 03:11 AM
Delavan's Avatar
I ran Prime 95 overnight (small fft) 8 hours stable...at 3825 (450FSB X 8.5)
Load temps 67-59-65-65 no issues. (TJunction set at 100 Celsius)
Idle temps 40-37-35-35
Vcore is 1.328V on load (in CPU-Z). Th RAM is running 1:1 ratio at 2.1V.
So what's next? I'm not interested in doing higher with the OC, so I assume I should start to work on lowering the voltage right? I my chip safe to operate at these settings for long term use? (I'll probably keep it for a few years)
The info on tjonction, max temps thermal specs, although published, are clear as mud, so it's real hard to get straight answers, lot's of different opinions out there...
