Old May 4, 2007, 10:03 PM
I've had the board for a couple days now and have had no real issues with it thus far - especially for being completely new to this thing. My only complaint is that with IDE devices, SATA and the power/hdd activity LEDs all needing to be plugged in, the upper-right section of the board got REALLY crowded when it came to wiring as well. Another thing that should be taken into consideration is that the 8 pin power connector is in the top left part of the board - which is great for top mounted PSUs - but not so much for those that are mounted in the bottom like the popular Antec boxes; especially with a bulky graphics card in the way! Other than that, flashing was easy and the installation of associated drivers and configuring the BIOS was self-explanatory. I'd suggest that you reset the BIOS to defaults straight off on the first boot though. For some reason mine had its multiplier at 8x (instead of 9x that's the default for the E6600). I'm not entirely sure if that was the only disreprency. It's recommended you set everything to defaults before you update the BIOS anyway so you might as well even if your settings aren't messed up from the get-go like mine!
Old May 4, 2007, 11:18 PM
DerekOldschool's Avatar
Thank you very much for the insight - this is the information that allows a consumer such as myself to "skate with my head up", so to speak.
Product reviews are all well and good, but it is in forums like this one where one has access to real world experience.
Keep em coming
i7-860 @ 4.0Ghz • EVGA P55 FTW SLI (E657-A51 Bios) • Thermalright ULTRA-120 Trueblack Rev.C • G.Skill Ripjaws 4G DDR3-2000 • Antec 850W TPQ • EVGA 780 Ti • Acer X263W 25.5" LCD • Crucial C4 256G • WD FAEX 1TB • LG DVDRAM GH20NS10 • Thermaltake Kandalf case • Windows 7 Pro x64
E8400 @ 3.96Ghz (1.42v) • EVGA 780i A1 (P08) • ZalmanCNPS9700NT • G.Skill 4G DDR2-1000 • eVGA GTX280SC 1G • Windows 7 Pro x64 • 1xSeagate Barracuda 7200.11 500G
Old May 4, 2007, 11:31 PM
r00tman's Avatar
Originally Posted by DerekOldschool View Post
I'll bet that board will sell for near $300 can when it first comes out - but like I said, I'm waiting for a few months anyway
thanks for the input!
Why not go for the EVGA nForce 680i LT?
[Workstation]
HERCULES: Intel Core 2 Quad Q6600 | EVGA 680i SLI | 4GB Patriot EP | 2 x 150GB WD Raptor, RAID 0 | EVGA GeForce 8800 Ultra | ATi TV Wonder Elite.
[Laptop]
PAN: IBM Thinkpad T42 | Pentium M @ 1.77 GHz | 1GB DDR-333 | 40GB HDD | DVD-/+RW | ATi Radeon 7500.
[Server]
ZEUS: Dell Optiplex G150 | Intel PIII 1 GHz | 512GB SDRAM | 500GB HDD.
Old May 5, 2007, 05:02 AM
Babrbarossa's Avatar
I've learned some good cable management trick for the p180 and the 680i- you can hardly see any now. The way to do it is to remove the right-side panel and drill a hole through the motherboard tray just above the eight pin connection, and route that cable behind the motherboard tray- you can route all the others behind tray too- there's not alot of room between the motherboard tray and the right-side panel, so it tricky to put it back on the first time, but the cables flatten out once it's on.
Old May 5, 2007, 04:28 PM
r00tman's Avatar
What case is this for?
[Workstation]
[Laptop]
[Server]
Old May 5, 2007, 07:39 PM
Antec p180
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 07:56 AM
DFI Infinity P965-S Dark keenan CPU's and Motherboards 10 July 26, 2007 11:30 AM
Another DFI Infinity Dark review by MadShrimps Babrbarossa Reviews & Articles from the Web 1 May 24, 2007 08:09 AM
2900XT CrossFire: 975X vs P35 by Anandtech Babrbarossa Reviews & Articles from the Web 0 May 17, 2007 08:58 AM
Intel D975XBX2 vs. the ASUS P5B deluxe….P965 vs. 975X philmar CPU's and Motherboards 51 March 28, 2007 04:12 PM
