Old October 19, 2008, 10:40 PM
CTA's Avatar
CTA CTA is offline
Default BIOS questions
i would like to understand more better
can you please explain what red text supposes do and can what...
please note that this is only example and for asus p5q... that i took it from other forums...
Code:
Ai Overclock Tuner [Manual]
CPU Ration Setting [Auto]
FSB Frequency [333]
PCIE Frequency [100]
FSB Strap to North Bridge [Auto]
DRAM Frequency [Auto]
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Manual]
1st Information: 5-5-5-15-3-52-63
CAS# Latency [5 DRAM Clocks]
DRAM RAS# to CAS# Delay [5 DRAM Clocks]
DRAM RAS# Precharge [5 DRAM Clocks]
DRAM RAS# Activate to Prechar [15 DRAM Clocks]
RAS# to RAS# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
  2nd Information: 7-3-5-4-5-4-6
  READ to WRITE Delay(S/D) [Auto]
  Write to Read Delay(S) [Auto]
  WRITE to READ Delay(D) [Auto]
  READ to READ Delay(S) [Auto]
  READ to READ Delay(D) [Auto]
  WRITE to WRITE Delay(S) [Auto]
  WRITE to WRITE Delay(D) [Auto]
   3rd Information: 14-5-1-6-6
   WRITE to PRE Delay [Auto]
   READ to PRE Delay [Auto]
   PRE to READ Delay [Auto]
   ALL PRE to ACT Delay [Auto]
   All PRE to REF Delay [Auto]
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Auto]
Ai Clock Twister [Auto]
Ai Transaction Booster [Auto]
C/P: A1 A2 A3 A4 | B1 B2 B3 B4
LVL: 10 10 10 10 | 10 10 10 10
******** Please key in numbers directly! ********
CPU Voltage [1.17500]
CPU GTL Voltage Reference(0/2) [Auto]
CPU GTL Voltage Reference(1/3) [Auto]
CPU PLL Voltage [Auto]
FSB Termination Voltage [Auto]
DRAM Voltage [Auto]
NB Voltage [Auto]
NB GTL Reference [Auto]
SB Voltage [Auto]
PCIE SATA Voltage [Auto]
Load-Line Calibration [Enabled]
CPU Spread Spectrum [Auto]
PCIE Spread Spectrum [Auto]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
what does FSB Strap to North Bridge" really mean? i mistook it as memory mhz?
in CPU configure
Code:
Max CPUID Value Limit
Intel(R) Virtualization Tech
CPU TM Function
Execute Disable Bit
why red texts must be disable and green text is enable?
Old October 19, 2008, 10:42 PM
FSB Strap to NB means it will allow your memory to properly run at a 1:1 ratio.
Old October 19, 2008, 10:46 PM
CTA's Avatar
CTA CTA is offline
hmmm... i see...
just curious 1:1 is the best method to have? or it could be 1:1 or 5:6?
Old October 19, 2008, 10:48 PM
1:1 is the best method for Intel.
Load Line calibration .. leave off.. its kinda like building a dam in a ram and not allowing it to flow properly.. it can cause damage.
Speedstep and C1E don't allow for stable overclocks if your overclocking otherwise leave them on.
Old October 19, 2008, 10:52 PM
CTA's Avatar
CTA CTA is offline
ok...
i dont have that LLC in my bios...
and i know speedstep C1E... actually i enable it and i dont see any stable problems o_O i just want to save some power and cool it at idle...
