ok well I spent some of my weekend playing with my e6600 and it refuses to run stable at anything higher than 3.32 lol I brought it up to 3.33 and it crashed in orthos after 1 hour. 3.34 results in a crash in 10 minutes and so on lol. 3.38 is the point where it wont even post. The highest I was willing to bring the vcore to was 1.55, wasnt comfertable goign any higher lol. So my final results for a L646G510 batch is 3.32 @ 1.5v (I bumbed it up to 1.5v just incase lol) running stable after 8 hours of orthos testing. It runs at 30c idle and 45c-50c under 90-100% load. But from what I read this is about as much as anyone else can squeaze out of the G510's anyways so im happy i guess Makes me wish I had just gone with an e6420 lol.
__________________ ABIT IP35 Pro e8400 @ 4.05Ghz EVGA GTX260@ 660/1250 4x1gig G.Skill 1066 @ 1080 5-5-5-15 Windows Vista Home Premium X64 Watercooled CPU: D-Tek fuzion V1 GPU: Swiftech MCW60-R W/ Moddified Uni-Sink Pump: Swiftech MCP655-B Rad: Swiftech MCR320 Res: Swiftech Microres |
Well-- that's not bad, but I'm not sure that you'd have any better luck with the 6420 (although it's cheaper) as they are now just lower binned e6700s- I think overclockers are going to be saving up for the e6700 more often these days.
__________________ Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
ya, oh well Im happy with my computer now lol. My 3dmark06 score went from 8000 with my old amd system to 10343 with this one so theres a slight improvment i guess
That's a really good 3DMark score given your gear and your settings. You GTS must be well overclocked, oui?
ha no, check the other post i made. I cant oc my 8800 gts and its just a stock gts no factory oc'ing.
Give this a look for graphics card overclocking: Bjorn3d.com -Overclocking the GeForce 8800 Series, Satisfying Your Daily Tech Cravings Since 1996 At any rate, did you try increasing the FSB voltage as well as the vcore? I found that I had to increase it in order to get to 3.2 at stock voltage. I'm at 1.35 right now at 3.2Ghz and I highly doubt it's going to take me that much to reach 3.4Ghz stable. |
lol that link was the first 8800 OC guide I ever read But I dont like playing with the bios, anyways rivatuner launched a new 2.01 version which works with vista and the new 158.18 driver. I installed that and had my 8800GTS running at 625/1020 @60C idle so riva tuner is now my program of choice as ntune still would not work.
This is my first tentative at OCing my E6420 L644G289...I know the batch has bad reputation. Well, I tried the "magic thinking" 8X400FSB, RAM 1:1, stock voltage. No Love. No boot. That was expected. Then a modest 8X333MHZ, RAM 1:1, stock volts,works good no problem. In the posts above ,you OC gods are suggesting; -Increase the processor's voltage a bit (small increments) -Increase of FSB volts a bit (what do you recommend?) I red posts about increasing the PCI-E bus speed by a small increment also (for some obscure reasons, to increase stablility...) So now at stock speed (Orthos), Speed fan 4.29 gives me a Temp1 of 42 Deg.Cel Temp2 of 27 Deg.Cel At 2.6Ghz(Orthos) Temp1 of 46 Deg.Cel Temp2 of 42 Deg.Cel I know it's nothing to write home about, but I'm going slowly but surely. Delavan
__________________ E6420@3.2Ghz/ Gigabyte P965-DS3 Rev.3.3 F10 Bios/2 Gigs Mushkin EM-PC6400/Arctic Cooling Freezer 7/GeForce 8800 GTS 640Mb SC 651Mhz-2020Mhz/Antec TP3 650W/Thermaltake Armor Jr./Seagate 160G/WD 250G/Audigy 2ZS/Logitech Z-2200 3DMarks06 (12223 pts) |
Before looking at increasing fsb voltage, have you dropped your mem down to the lowest possible setting in order to find your proc max? My new mobo is finally shipped (MTL this morning.... :) ) so I'll have a chance to play along shortly. (LG44G289 as well.... :) ).
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Intel Batch Codes | enaberif | CPU's and Motherboards | 2 | February 14, 2008 11:56 AM |
| Retrieving XSerial Number from Proggy? | frosty | Troubleshooting | 2 | December 16, 2007 09:53 AM |
| PS3 problems abound as second batch to hit shelves in December | Gav | Gaming | 13 | August 8, 2007 05:40 AM |
| P180 + 680i rig number 2 - WC | 3.0charlie | Water Cooling | 10 | June 13, 2007 02:37 PM |
| TechSpot stages Core 2 E4300 vs. E6300 overclocking battle | Supergrover | Reviews & Articles from the Web | 5 | January 25, 2007 02:49 PM |
