Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old May 9, 2007, 12:25 PM
sswilson's Avatar
Super Moderator
Originally Posted by JayDee View Post
I came across that thread at NCIX as well - After I put in an order for a E6600. Too bad that a poor overclock isn't accepted as a vaild RMA reason. For 99% of the buyers (Dell/Gateway/... bulk box buyers) it makes no difference but the OC is a big part of the decision to buy for the other 1%.
Yeah, there are very few venders who will offer to check steppings, and some of those who do will charge a premium for the service.
This used to be a big issue with S939 chips, not sure what the market is like for C2Ds.
This is the kind of service that a local vender can shine at.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old May 9, 2007, 08:04 PM
One of the Thermalright series - if NCIX ever decides to get stock. :P
At any rate, I can't possibly see it requiring such an extreme increase in voltage to carry this processor a couple hundred mhz higher. So, I either got really lucky in the batch or those guys in that thread are doing something really wrong.
Old May 9, 2007, 09:08 PM
Supergrover's Avatar
Super Moderator
Well I have been lucky with my 939 cpu's BUT before I open the packages I ran the stepping's just so I wouldn't get burned. A restocking fee is better than having to flog it on Ebay, of course you run the risk with the replacement.
Rocket Surgery-A Combination of Rocket Science & Brain Surgery
Nothing in Moderation
Problems with your DC Order? PM Direct Canada's Forum Rep
Old May 11, 2007, 11:37 PM
Level up: 85% Level up: 85% Level up: 85%
Level: 12 - 61 points to level up
ok, well I finnaly got my case that I have been waiting for about a week now so I can use my new e6600.
Its stepping is L646G510
So far Ive gotten it to 3.32 @ 1.45v
I've run it through a full 3dmark with no error and currently running orthos blend test Priority 9 and cpu temps are holding steady at 55C with my zalman 9700
Running it at 3.4 gave me a BSOD in 3dmark half way through the second CPU test so I'll play wih it more tommorow and see what I can get it to lol.
Old May 12, 2007, 07:13 AM
JayDee
Guest
Posts: n/a
My new rig arrived yesterday but, unfortunately, I won't have a chance to built till Monday or Tuesday
My batch is L704 A945 Malay. I checked all the links and I didn't see a single "L7" (a 2007 production run I think). From what I've seen the older L6 weeks OC better than the ones later in the year so I hope the L7 breaks that trend. Oh well the proof of the pudding is in the voltage and we'll see what I can get from the L7
Old May 12, 2007, 07:58 AM
Babrbarossa's Avatar
Super Moderator
Great news guys! Rag- 55 seems a little high with that voltage and that cooler- maybe the thermal paste just needs to settle. Good news that you were able to break 3GHz though, and without too much juice.
Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old May 12, 2007, 08:01 AM
check this link out here:
NCIX FORUMS - Recent Steppings - Intel Core 2 Duo E6600 Dual Core Process...
2 guys with L7 chips. One even ha a A batch like you and managed 3.2 at stock voltage. Its to bad he never posted his final OC.
Oh and my G510 ran for 8 hours in orthos last night at 3.32 and no crashes.
Old May 12, 2007, 05:09 PM
JayDee
Guest
Posts: n/a
Thanks for that info ragenrok
Helps me to have a more positive attitude as I look to the build as I've been thinking newer isn't necessarily better when it comes to C2D production weeks.
  #19 (permalink)
Old May 13, 2007, 09:03 AM
I have checked out the C2D lists you were good enough to post but I can't seem to find out what week & code my E6400 is. The lists all insist that the info is on the cpu and box and is listed like ..L6xxA***. But the only info I have is...FPO/Batch#... 7639A235 (Pack Date 01/31/07). So I'm guessing the code is A235 but have no clue as to what week 7636 would be???? CPU-Z shows Stepping 6 & Revn B2.
Any ideas??
  #20 (permalink)
Old May 13, 2007, 04:19 PM
7639A235
Okay, this is a little wierd. Generally it's year, week, batch and some other batching markers. As a result, 76 doesn't make a whole lot of sense. Take a look at the processor itself and see if there's a similar number.
Forum Jump
Search this Thread:
Advanced Search
Intel Batch Codes enaberif CPU's and Motherboards 2 February 14, 2008 11:56 AM
Retrieving XSerial Number from Proggy? frosty Troubleshooting 2 December 16, 2007 09:53 AM
PS3 problems abound as second batch to hit shelves in December Gav Gaming 13 August 8, 2007 05:40 AM
P180 + 680i rig number 2 - WC 3.0charlie Water Cooling 10 June 13, 2007 02:37 PM
TechSpot stages Core 2 E4300 vs. E6300 overclocking battle Supergrover Reviews & Articles from the Web 5 January 25, 2007 02:49 PM
