Old October 18, 2008, 06:08 PM
CTA's Avatar
CTA CTA is offline
Default mbios...?
Modded ASUS P5Q/Pro/Deluxe/Premium BIOS - XtremeSystems Forums
its very interesting article... is it really safe to use mbois?
Old October 18, 2008, 06:15 PM
Yah? How about you find the thread on the biostar?
Or the fact he nuked his own board with that bios.. or the fact people have nuked their biostar boards cause of him.
Absolutely not recommended.
Old October 18, 2008, 06:34 PM
CTA's Avatar
CTA CTA is offline
do you mean Biostar T Power I45 BIOS thread - XtremeSystems Forums
Old October 18, 2008, 06:45 PM
sswilson's Avatar
I myself wouldn't use a modded bios unless it addressed a specific critical issue (4 sticks mem on the DFI Ultra-D comes to mind) and it had a really good track record. Seems to me I remember that some modded bios' also can't be just flashed back to normal without jumping through a few hoops.
Only recommended if you either really don't care if the hardware dies on you, you have a spare bios chip kicking around, or it does something that you really need.
Old October 18, 2008, 07:04 PM
Xilikon's Avatar
I agree with sswilson and pick a modded bios only for a specific reason. Otherwise, I trust the manufacturer bios more ;)
Xilikon - Team 33
Proud to be [H]ard !
Old October 18, 2008, 07:08 PM
CTA's Avatar
CTA CTA is offline
ok... good advices... so i will not use it...
i was just wondering... :whistler:
thank you
Old October 18, 2008, 07:29 PM
be careful as he did release one BIOS that bricked some P5Q Pros. He changed too much, started renaming things and it was no good.
I've tried all of his BIOSes and all the official Asus ones on my p5q-e and ended up using his 704m BIOS. That said, I agree you probably should only use the modded ones if you need them. I was trying to find the best one for OCing, plus the P5Q-E has a backup BIOS chip so it's no biggie if I flash a bad BIOS (unless it's super-borked).
To be fair, he got his Biostar only a few days ago, people using modded BIOSes should know they are playing with fire, and this thread is about his P5Q BIOSes not his Biostar ones.
Originally Posted by ket
its naturally untested as I don't have the TPower yet, so use it at your own risk.
Can't say the guy didn't warn people.
Old October 18, 2008, 08:17 PM
Do you miss the memo he released the bios without even trying it himself?
Thats pretty shoddy work if you ask me.
Old October 18, 2008, 11:56 PM
burebista's Avatar
I'm on m1402 on P5Q-E and everything is fine.
But I always wait a couple of days to see peoples reports about his modded BIOS.
For me is useless because I'm not a clocker and I don't have any problems with my setup, but for clockers/benchers might worth a try.
Old October 19, 2008, 01:01 AM
i dont see the point about modding a bios. I think there is a differance betwween being a hardware geek, and a electical engineer.
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
