Old October 17, 2008, 07:24 PM
Default Inspiron 1501 Cpu upgrade
I bought a TL-60 cpu to replace a sempron in my laptop. It is compatible I know how to do everything hardware related, but do I have to do anything else? eg. bios?
Old October 17, 2008, 09:17 PM
Eagle Eye's Avatar
Provided the motherboard supports the cpu you should have no problems upgrading, much like a standard desktop motherboard as long as it supports the cpu its should be nothing more than a quick switch.
The current dell bios for the Inspiron 1501 fixes only an "erroneous bad battery message during post" you can find that here: Drivers and Downloads
Althought be wary of DIY upgrades if I am not mistaken as such will void your warranty from Dell, although I am not 100% sure of that.
I would also like to refer you to this thread it might have some useful information: Dell Inspiron 1501 CPU Upgrade
Good luck and welcome to HWC ,
EE
Old October 17, 2008, 09:27 PM
Althought be wary of DIY upgrades if I am not mistaken as such will void your warranty from Dell (correct me if I am wrong)
EE
Yea I saw that thread first. It had some good info just didn't know if I had to mess with the bios. thx
Old October 17, 2008, 09:28 PM
Eagle Eye's Avatar
Read my orginal post I was editing some content regarding the bios.
