-   -   Is Q6600 overkill for my needs? (http://www.hardwarecanucks.com/forum/cpus-motherboards/10571-q6600-overkill-my-needs.html)
Kayen October 4, 2008 09:24 PM
I'm currently using a Q6600 at stock, and it is more than what i need at the moment,
i do light gaming, and have a spare e2180, and i think i might sell both and buy an e5200 as it runs cooler and sucks up less energy.
All i do is COD4 atlantica online, CSS, CS 1.6, and SC 2 when it comes out.
I use mainly for web browsing though.
For gaming i use 9800GTX+ which should handle most things.
Also for CPU cooler i have a TRUE on the way ( Thanks encorp! ) .
enaberif October 4, 2008 09:26 PM
Way overkill :)
werty316 October 4, 2008 11:30 PM
A quadcore is overkill for alot of users and just like them, its overkill for you as well.
1Tanker October 4, 2008 11:41 PM
Sounds like a good plan. Either an E5200 or E7200.. i wouldn't suggest going below the 5200 though.. the 9800GTX+ needs some CPU power to feed it. :thumb:
belgolas October 5, 2008 06:50 AM
Yeah sell both and buy a decent dual core 45nm. You wont see a difference in performance.
matsta31 October 5, 2008 07:26 AM
the new petium 5200 is like 100 $ ? You can easily get this by selling your cpu.
b1lk1 October 5, 2008 07:48 AM
I would keep the Quad and just run with speedstep enabled and that will cut the power needs down. The Q6600 will have a longer lifespan of usefulness than any dual-core. Eventually it will be worth having a quad in a normal PC.
encorp October 5, 2008 08:22 AM
I'd get a nice dual core if I were you; that true will keep it super chilly.
I use quad cores because I multi task like a machine; I always prefer more tasking performance over higher clocks so I build my systems with high amounts of memory and as many (4) cores as I can. I like to be able to do whatever I want; all at once.
geokilla October 5, 2008 08:40 AM
Run F@H then it wouldn't be overkill anymore.
If you really want to sell it, sell both then get a E7200 and overclock it to around 3.8Ghz. Most E7200 can hit 3.6Ghz with ease.
jay51 October 5, 2008 01:54 PM
why not just keep the 6600,save some money ....are dual core intel's eg:5200,7200,even 8400 any better than Q6600..if not OC'n anything..
i thought quad would be better,or q6600 oc'd to 3ghz better than the duals listed above?
