Old October 5, 2008, 04:10 PM
Kayen's Avatar
@ geo - i do run F@H but on GPU client.
I think i might just leave in the Q6600,kinda lazy to get rid of it, but all that's left is to get rid of the e2180.
Also is the intel speedstep enabled by default - as in it lowers my multi to 6.0 right?
Anyways i'm not done with my PC yet - I got a harddrive (old maxtor IDE...manufactured in 2000 LOL ) that's louder than all fans on my antec 900 on high....
Old October 7, 2008, 07:17 PM
thenewguy001's Avatar
If you ever have to encode video, like I'm doing now to fix a broken video file, you'll be glad you have a quad.
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old October 7, 2008, 07:33 PM
Menello's Avatar
If you want to be ready for the future, you may as well keep the Quad.
As for when that future comes... who knows?
The box:
Mobo: eVGA NF66 nForce 650i Ultra SPP
CPU: Intel Core 2 Quad Q6600 @ 3.03GHz
RAM: 1x2GB
OCZ DDR2-800 PC2-6400
+ 2x2GB Crucial DDR2-800 PC2-6400
= 6GB RAM (finally more than 2GB!)
GPU: XFX GeForce9800GTX+
HDDs: 500 Seagate, 640 GB WD Caviar Black
PSU: CoolerMaster 600W
Old October 7, 2008, 07:48 PM
Kayen's Avatar
Encoding video faster on quads?
Because, yes i do encode videos quite often... i'm fond of the divx format...
Old October 7, 2008, 08:06 PM
MpG's Avatar
MpG MpG is offline
Open up your task manager, then do some encoding. Afterwards, check out the usage of your four cores. If they're averaging over %50, you're technically benefiting from that Quad. And it might not hurt to keep that E2180 around, in case you ever have to jump start a socket 775 board with an early BIOS that doesn't like newer processors.
Old October 8, 2008, 09:20 AM
I'm re-encoding a 1gig movie that got corrupted somehow. My CPU usage hovers around 80%+ over my 4 cores, and it still estimates to take about 6-7 hours to complete. I can't imagine how long it would take on a dual core...
i5 2500K @ 4.0 GHz
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Seasonic 760W
Old October 8, 2008, 10:30 AM
holy crap dude!!! get some better software, i can re-encode an entire dvd in 30 - 40 mins with my quad.
KEEP your quad. video encoding is one of the few things that truely benifit from multi threading
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old October 8, 2008, 10:36 AM
cwestwell's Avatar
Seems redundant though to sell a processor like the Q6600 which probably cost $300-$400 when you bought it ...depending on how long ago that was....to sell it used you would likely get only $150 if your lucky or you find a sucker to buy it for more...I would keep it, you already have it and it's working well if your concerned about power under clock it or use many of the power save options out their. I would hold onto your Q6600 though it's a great CPU and their is no such thing as "CPU overkill" even if you don't use all of it...it's still fast.
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
  #19 (permalink)
Old October 8, 2008, 10:41 AM
"Quote This..."
If they are using all 4 cores at all, you are benefiting. Scheduling those tasks over 2 cores involves timeslicing and additional overhead, wait cycles.
  #20 (permalink)
Old October 8, 2008, 11:07 AM
MpG's Avatar
MpG MpG is offline
Agreed, but it's still a little vague at that point. If you were only getting %10 usage across four cores, it'd be a little harder to justify the extra two cores. For example, CoD4 uses all four cores on my machine, but the usage is fairly minimal across three of the cores, which is why you won't see me recommending a quad to get better frame-rates in that particular game. Once you exceed the %50 mark on all four cores, there's absolutely no question that the quad-core is working the way it's designed for.
