Originally Posted by b1lk1 I got burned by S939 dying fast, but that is a problem for all platforms. |
dont forget that since AMD release their A64 chip they change platform 3 times (754, 939 am2) and ther am3 is coming
while Intel drop the 478 to LGA 775, and they are still using it.
my personnal opinion is that keeping a platform for a long period of time is thebest way to do it, ppl will upgrade their cpu without changing bangwagon
if you're a 939 user and wanna upgrade to dual core cpu, what will you look at? only 939 DC cpu left in stock is tigerdirect x2 3800+ which is not a high end chip. so you will start to look around and see that if you wanna have more cpu power you have no other choice to chnage your rig, then you will change to C2D. But if amd ddint drop the 939 line, you would still probably be in the AMD bangwagon
and dont forget that M$ didnt support the NF3 (754) for vista, or only offer limited support. with all that BS going around, we 939 user will drop just like the 754 user where.
that just my 2¢ but i think that the change of platform killed AMD has well has the C2D did
