Old September 17, 2008, 01:38 AM
automatic's Avatar
Default Hmmmmmmmmm.
As some of you may remember I posted here earlier about upgrading my CPU and if I should install it (and my new sunbeam tuniq tower) myself (with no prior experience installing these kind of things).
So I installed the fan and new chip with the utmost care and following instructions of course. Afterward I closed the lid and booted up but sadly my monitor didn't receive any picture. I checked to see everything was properly plugged in and could see the power button on my monitor was in fact on, though still no picture. Then I took it out and put the old CPU back in and now my monitor functions absolutely fine.
I'm really stumped on what the problem is, my guesses:
- the new cpu is dead
- i don't have good enough power supply for the new chip
- i suck at installing stuff and ruined my computer
What do you guys think is the problem?
Keep in mind:
- The old CPU is a E4400 and the new CPU is a E8400.
- I have a 500 Wt power supply.
- I'm inexperienced in installing stuff (though I don't think this is the problem).
Old September 17, 2008, 02:08 AM
burebista's Avatar
What MB? Did you update your BIOS before putting E8400? Maybe it's not supported in your current BIOS version.
Old September 17, 2008, 05:16 AM
bojangles's Avatar
Please tell us your motherboard and BIOS revision. You may need to flash the BIOS chip to the latest firmware.
Double check to make sure all the required cables are plugged in. Do you have a PC speaker that beeps entering into BIOS? Make sure nothing on the board is grounding onto the case.
The name of the PSU could help too.
Old September 17, 2008, 08:22 AM
sswilson's Avatar
75% chance that doing a cmos reset after you install the new cpu will get you up and running.... :)
Old September 17, 2008, 09:30 AM
Yeah a lot of the time thats the only issue. Just look at it like the mobo misses the old cpu a lot and unless you whack it over the head it won't let go enough to accept the new one into it's socket LOL
Old September 17, 2008, 01:52 PM
automatic's Avatar
Wow, none of you think I need to get a new power supply?
my friend had me convinced it would work if I upgrade to a 650 wt.
Old September 17, 2008, 01:54 PM
sswilson's Avatar
Best bet is to try the "free" stuff first, but yeah, if you're running a no-name 500W it could probably stand to be replaced.... :)
I'm still betting it's the C-Mos. :)
Old September 17, 2008, 01:55 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I doubt it.
Old September 17, 2008, 02:03 PM
reaverclan's Avatar
yup clear that cmos and check your bios revision
Old September 17, 2008, 02:25 PM
automatic's Avatar
it's not a no name it's an Antec! :P
