| Heh..... First off... Ctrl-F1 from the main bios page will unlock all of your advanced memory settings..... :)
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 931BF DFI P965-S Dark / Q6600 / 2X1 Gig Crucial Ballistix PC2 8500 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / NEXUS NHP-2200 / Swiftech H20-220 / Highspeed PC Tech Station / BENQ FP91G+ |
| I plugged in all my equipement and it started up without any issues! Now upon entering the BIOS(version F7) I begin to ask myself...where are all the options??? Press Ctrl+F1 at the main BIOS page. This will give you all the memory options. No memory tweaking options? Stupid memory divider system? Voltages are hard to read, besides the fact that they have a HUGE droop!!! ![]() ![]() If I set my vCore to 1.45...I end up getting 1.41....and that will go down to 1.39 under load! So lets notYou may have the PC Health stuff enabled. You will want to go in a disable the following: - Disable the CPU Smart Fan Control so your fan is running at max. even discuss the other voltages setting options! And hot....no I must say HOT that the NB gets....I burned myself! And that was on standard settings....nothing OC'ed yet! This is normal. Get yourself either a aftermarket NB heatsink or a 40mm fan. So then the overclocking part starts... The E6850 I have is not a real good one...it will run up to 3.850GHz on this board but is not real stable at that point. On my old 680i it did the same...but that boards is now on its way for a RMA session. 3.6GHz so far is stable but what I don't understand is, my temps remain nice and low...28C idle and 48C under Orthos load, so how come if it gets any higher than that it will not remain stable? And what should I do to make my RAM run as fast as possible eg. 1150MHz under 5-4-4-8 timings without taking away from the CPU overclock? If you want to run your memory above the rated speed of 1066 then if you set the memory multiplier to 2.5 which wiould give you 1125MHz with a 450 FSB or drop your FSB down to 400 set your CPU multi back to 9 and set your Memory multiplier to 3 which would give you 1200MHz for your memory. Here are the rest of the settings. Robust Graphics Booster: Turbo CPU Clock Ratio: Default setting CPU Host Clock Control: Enabled CPU Host Clock Frequency (Mhz): Set to your desired FSB PCI Express Frequency (Mhz): 100 C.I.A.2: Disable System Memormy Multiplier (SPD) 2.5 or 3 depending if you have your FSB at 450 or 400. High Speed DRAM DLL Settings - Option 2 DRAM Timing Selectable (SPD): Manual. ************** Standard Timing Control ****************** CAS Latency Time: 5 DRAM RAS# to CAS# Delay: 4 DRAM RAS# Precharge: 4 Precharge delay (tras) 8 Keep in mind you may have to loosen your timings if it is not stable since you plan on OCing your memory. The rest of the memory settings leave on Auto. DDR2 Overvoltage Control - This works on +0.1 for 1.9v, +0.2 for 2.0v, +0.3 for 2.2v, etc.... |
| Jeez.. step back, relax, take a breather... 1. Flash to BIOS F8a. 2. Like Mr. Wilson and Balistx wrote, CTRL+F1 on the main page will show advanced settings. 3. Yes, the board has a vdroop, like many other boards. 4. Members don't believe me when I say that the board runs hot. Either change the NB block or slap a Spot Cool on top of it. Keep a close eye also on the SB block. 5. With BIOS F8a, a new Ram multi of 2.0 is shown - this will allow you to run 1:1. No more Ram problems. 6. I never use software for oc'ing. Ever. On my DS3L, I can push my Q6600 to 4.2GHz, unstable. ATM, I managed 3.7GHz, folding 24/7. Next step will be 3.8. Yes the board droops, but it's not too bad - heck this is a 90$ board, not a 250$ monster...
__________________ Gigabyte GA-X48-DQ6 (dead) - QX9650 @ 3.0GHz - Corsair HX1000W - Raptor 74Gb - Mushkin XP2-8000 2x2Gb - BFG GTX280 (dead) - Wc'ing: Swiftech Dual rad w/Noctuas - Lian-Li PC-V1000 Gigabyte GA-EP45-DS3L - Q6600 @ 3.0GHz - Corsair HX620W - Raptor 37Gb - Mushkin EM2-6400 2x1Gb - BFG GTX280 (Ati 300SE Temp.) - Xigmatek HDT-S1283 - Antec Sonata II |
| What they said... The scythe mini kaze is like 4 bux and silent as a mouse fart, screws right to the NB sink and brings my temps from 45 to 32, done. I have a Noctua NB HS on another one, gets me to 29 with a kaze on it, not worth it IMO. I can post at 4.2 on a 6750, but thats all, but yes, the droop is huge, just compensate I guess...
__________________ My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c |
| LOL guys! THX a lot for your tips....See what happens if you don't read the manual first? They call that being an eager beaver as well....LOL I'll report back a little later how things are going! Lets see how the BIOS flash goes on these boards....
__________________ |
| It's a good board, with plenty of settings but with a budget price. My main concern is the vdroop, but you sure can compensate. Next is the very-high NB temp, but then again this also can be taken care of.
| Quote:
I call that being a nurse... if you look at the rest of the gigabyte line, there really isnt a whole lot different all the way up, unless you need xfire or raid that is, pretty much the same board...
| Quote:
BTW, I was able to boot the E8400 to windows with the F7 Bios, then upgrade it with the @BIOS s/w. This was a concern for me before I installed, wasn't sure if I'd have to boot with my E6400 first. Glad it worked, should also work for those of you thinking about this combo. Suggestions for software for monitoring NB temp? I like Coretemp but it only shows CPU temps.
__________________ Intel E8400 Asrock X48TurboTwinsWifi Diamond HD4870 512mb G-Skill DDR2-1000 4GB Creative Xtreme Audio PC P&C 750W Quad Silencer Antec 900 Logitech G-15, G-5 Westinghouse 24" LCD WC Loop: Swiftech Apogee GTZ Danger Den CPX-Pro Black Ice GT Stealth 240 Rad |
| Yes disable the CIA2 feature. I had this enabled when I had my DS3L and it was wrecking havoc on my OC. So you are saying with the F7 BIOS the E8400 boots. Did you have any issues with using the @BIOS software? |
| Thread Tools | Search this Thread |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/cpus-motherboards/4366-ga-p35-ds3l-oc-time.html | ||||
| Posted By | For | Type | Date | |
| Choosing between ASUS and GIGABYTE - Page 3 - Overclock.net - Overclocking.net | This thread | Refback | September 29, 2008 09:36 PM | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Gigabyte GA-P35-DS3L Northbridge? | Evilyeti | CPU's and Motherboards | 9 | April 26, 2008 02:11 AM |
| GA-P35-DS3L & OCZ2P8004GK = Trouble | SugarJ | CPU's and Motherboards | 16 | March 9, 2008 12:44 PM |
| Gigabyte GA-P35-DS3L and G.Skill RAM | Supertrash | CPU's and Motherboards | 3 | February 21, 2008 01:40 PM |
| Helping a Friend OC GA-P35-DS3L | BALISTX | Overclocking, Tweaking and Benchmarking | 34 | February 7, 2008 01:54 PM |
| Ga-p35-ds3l | mgp141 | CPU's and Motherboards | 3 | January 8, 2008 10:59 PM |
