<~----> MurderBox - Beauty and Power at a price - Page 3 - Hardware Canucks
Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Computer & Electronics Hot Deals
  #21 (permalink)
Old July 31, 2008, 04:42 AM
Digitaldemon's Avatar
Amazing piece of work , very nice layout and clean lines.
  #22 (permalink)
Old July 31, 2008, 07:56 AM
Beermaster's Avatar
BUt still look at that price, ouch
i would still buy it though, to lazy to do it myself
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov – Acer One*8gb SSD*WinXP pro
Tathar – WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
  #23 (permalink)
Old August 1, 2008, 10:33 AM
Hey Guys. :)
I have to make this post so I can make a post with a link.
  #24 (permalink)
Old August 1, 2008, 10:39 AM
Originally Posted by enaberif View Post
I just wanna know what type of heat shrink tubing he used.
3:1 or 2:1 and the size.
I've found the best quality heat shrink is the 3:1 dual walled w/ glue liner.
RP Electronics - Test Instruments , Power Supplies , Inverters , Electronic Project Kits and more!
There's tons of cheaper stuff available out there but I've found this to be the best - especially if you need the sleeving to hold in place; ie: when sleeving SATA cables.
  #25 (permalink)
Old August 1, 2008, 10:42 AM
SugarJ's Avatar
Cheers Charles!
Kudos to you for giving up your source so easily!
Beautiful looking systems, by the way.
  #26 (permalink)
Old August 1, 2008, 10:48 AM
sswilson's Avatar
Yes, great looking rigs!!! Certainly something I'd be looking at if I were looking for a boutique build. I especially like the look of the black sleeving over the tubing, and an absolutely amazing job of making everything look like it came off of an assembly line.
I've noticed that quite a few boutique builds look like they're just thrown together, yours looks like something an engineer spent over a year designing. Great job!!!!
(Gotta get some 4870s up there as a choice though.. :) ).
  #27 (permalink)
Old August 1, 2008, 11:03 AM
Thanks Guys! :)
I came over here after Matt emailed me and must say, I really dig the vibe of this place. I also really appreciate all the positive support and enthusiasm for what I'm doing. I've got lots of ideas that will soon be revealed and I hope to be able to contribute to the modding community. A community that has given me so much.
Oh, i'll get on those 4870s, cheers! :)
  #28 (permalink)
Old August 1, 2008, 11:49 AM
Awesome man! Good to see someone of your status here :)
Another question.. how do you cut your sleeving to get a nice clean cut without frays? I'm still trying to find a good way.
Right now I wrap a piece of electricians tape around the area I want to cut then melt the sleeving and remove the tape.
  #29 (permalink)
Old August 1, 2008, 12:25 PM
lowfat's Avatar
Do a nice quick cut, then run a soldering iron quickly across the cuts.
  #30 (permalink)
Old August 1, 2008, 12:31 PM
sswilson's Avatar
If you want more rigidity to your heatshrink you can always use 2 sleeves of different grades, the larger (diameter) one shorter than the smaller. This allows for a rigid overall sleeve, but allows some play at the end.
