Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Computer & Electronics Hot Deals
Old June 29, 2009, 07:43 PM
Yoda8232's Avatar
Default OCZ ModXStream Pro OCZ700MXSP 700W for $75.99 + Free Shipping
Newegg.ca - OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Power Supplies
Fifty bucks off the original price then a $30 USD rebate then free shipping, this is a great PSU. It's 80 Plus, modular and delievers 700W of constant power so that means it actually can supply 718.1W if you add up all the watts.
Old June 29, 2009, 08:52 PM
geokilla's Avatar
How does the public view this compared to other modular PSUs, such as the Corsair HX series? The Corsair PSUs have established a name for them in the computer market and all of their PSUs are excellent.
Yoda, consider making one thread listing these hot deals instead of making separate threads in a short time span. Both this and your TX850 thread is from Newegg and were made in a short amount of time. If I was a mod, I would merge the two threads together.
And same goes to your Rosewill thread. Plus Rosewill is a Newegg brand and if I'm correct, it's not that good.
Old June 30, 2009, 12:21 AM
Chilly's Avatar
The brand slapped on the side of the PSU matters not, the OEM who makes them does. The reason Corsair PSU's are almost always recommenced is because a lot of them of them are based on a CWT design, and while it is an older design, its a very solid, reliable OEM. The rest are based on Seasonic, also a great OEM.
I can't find any info on the OEM of the OCZ PSU, but from what I read its rated at 100,000 hours @ 25c which doesn't bold well for it(most GOOD OEM designs are rated at 100,000 @ 40c or 50c). I suspect that the 700Watt OCZ is really a 500-600Watt design pushed to its limits in disguise.
Old June 30, 2009, 12:30 AM
CroSsFiRe2009's Avatar
Yep..some unkown Sirtec brand PSU according to [H]
Old June 30, 2009, 12:40 AM
Chilly's Avatar
Well, there you go, I wouldn't touch the PSU with a ten foot pole, way better brands and possible buy's at $75.
Old June 30, 2009, 12:51 AM
Yep..you got it right Chilly
However, I find the OCZ GameXStream and Stealthstream to be pretty decent if you can get them on sale. No match for corsair but good daily workhorses.
Man, to think that this 700W GameXStream is better than the modxstream is pretty funny. Not sure if I remember correctly but I think the modxstreams were pretty bad overall except some of the later ones according to a few reviews I've read.
Old June 30, 2009, 07:52 AM
Varroa's Avatar
Just had a 600Watt GameExtreme die on me after only about 1.5 years of lite use (200watt max draw). My buddy also had his die after less than a year. I'm not too impressed with OCZ PSUs. I had it running in a windows home server when it died and it wasn't even powering a video card. I've got cheap Sparkle brand and Seasonic brand 400 watt PSUs that are running higher loads and are doing much better. My two Corsairs are all doing great as well. I replaced the PSU with an Enermax pro 82+ (all I could get at the B&M in my town on short notice) so I will have to see how that goes. So far it seems like a decent PSU.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old June 30, 2009, 08:35 AM
b1lk1's Avatar
OCZ has not produced a decent PSU for some time. Best to avoid them really........
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old June 30, 2009, 09:13 AM
Cowboy's Avatar
IMO, this is not a deal:
It is the price this PSU SHOULD be. I wouldn't touch one of these PSU's even if you paid me to use it in my rig.
Old June 30, 2009, 09:18 AM
geokilla's Avatar
My GameXStream 600W is still running strong. Let's see what happens in the future...
As for the ModXStream. Thanks for letting me know to stay away from it :)
[FS] OCZ ModXStream 500W antaholics Buy/Sell & Trade 0 April 27, 2009 03:57 PM
FS: OCZ EliteXStream 800W (new), ModXStream Pro 600W; DFI LT X48-T2R; 2x ATI HD 4850 S_G Buy/Sell & Trade 10 October 17, 2008 01:50 AM
OCZ Technology Unveils ModXStream Pro Series Power Supplies MAC Press Releases & Tech News 0 August 18, 2008 09:04 PM
