Old July 31, 2008, 10:39 AM
ebdoradz's Avatar
Default Ebz watercooling project
Ok, since a couple of members went to watercooling in the past few weeks, and since it made more then a year or so that i realy wanted to watercool my computer i have decide to jump on it and rebuild my system.
Systeme spec are the following :
AMD Opteron 165 CCBBE0617 (golden chip) @ 2.8ghz @1.28V (stock 1.8Ghz 1.35V)
DFI Lanparty nF4 Ultra-D Mod to SLI
2 x 1gb DDR500 OCZ Gold Gamer Xtreme XTC
2 x 80gb sata2 raid 0
Sony DVD-rw
Corsair HX620W modular PSU
Thermaltake Armor Case
The watercooling parts list is the following
Thermochill PA120.3
Swiftech MCP655
D-tek Fuzion v2 cpu block
D-Tek Fuzion V2 gfx vga block
Swiftech MCRES or DD Fillport (have both)
Masterkleer 7/16 tubing
D-tek High flow 1/2'' barbs
3 x Silverstoneteck FM121 fan
Swiftech RadBox
I have receive so far the rad, pump and cpu block
the rest should arrive monday or so
i have mount the fan on the rad with #8 - 1-½'' screw. for some reason the #6 screw everyone recommended here were slack on my PA120.3 rad
mounting the rad with the rad box was a charm but i found the rad box not to be very secure compare to the size of that PA120.3
i have also raise my Thermaltake iCage a couple bay up so i can place the pump at the bottom of the case.
i have sleeved the fan wire with the yellow sleeving kit i have bought @ DC last year when i bought my case. that way i dont have tons of wire messing at the back of my case.
i had to remove the LGA775 fast mounting that was on the fuzion cpu block and replace it with the universal mounting kit that was include with the block.
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old July 31, 2008, 10:52 AM
Cptn Vortex's Avatar
Ou! Looks like you should get some nice numbers with that RAD on that CPU! Its Massive!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old July 31, 2008, 11:26 AM
ebdoradz's Avatar
im hoping better temp then air on both the x1950xt and the opty ...
with that freezer cpu cooler im idling @ 30C and full @ 43C
VGA is another story idle @ 55, full @ 85-86C
Old July 31, 2008, 11:52 AM
3.0charlie's Avatar
I think that this PA120.3 is a wee bit too much for the Radbox. Any way you could support it?
Old July 31, 2008, 12:05 PM
ebdoradz's Avatar
no idea .. custom rad box !?!?! i might try to do it a little leg to help maintaining the rad at a vertical position. otherwise it seems solid but not has i was expecting
Old July 31, 2008, 12:52 PM
3.0charlie's Avatar
Damn, that one will be easier in French. Y faut le supporter pour empecher le Radbox de plier, comme c'est le cas dans la photo. Y faudrait le garder bien droit, a la verticale. ca aiderait le radbox vu que c'est du plastique.
Old July 31, 2008, 01:13 PM
magictorch's Avatar
Very nice indeed.
If I were you though when your attaching the tubing it would be a good idea to unclip the radiator from the case-otherwise you could break the attachment. Looks like you have plenty of room to wrestle the tubing onto the pump which is good.
Old July 31, 2008, 01:16 PM
3.0charlie's Avatar
What I wrote in French is exactly that: the radbox is already bending under the weight of the rad - with no liquid in it yet.
Old July 31, 2008, 01:34 PM
magictorch's Avatar
mmm french is on my to-do list. Alas a long time ago I was stranded in the bottom french set following a move to a new high school- I had no chance.
Hopefully once the tubing is attached it will provide some extra ridigity. But I hadnt noticed the bend in the top photo -it must be very heavy I've tried bending mine as I type.
Old July 31, 2008, 06:23 PM
ebdoradz's Avatar
thank you for your french word buddy... lol
i will make a little leg or something like to to help support the bottom of the rad and keeping it vertical
