Old June 24, 2008, 02:25 PM
Default [OnGoing Project] Hacked 690 ** updated **
Due to costs.. time.. and every other thing out there this has taken longer than expected but when its done I gurantee it'll be one of a kind hehehe.
Heres a sample right now.. bottom half will be holding all my water cooling parts.
In case anyone is wondering... its just shy of 29" tall :P
Case (Raw Form)
Reservoir
Dust Screen Far Away
Dust Screen Up Close
Radiator Mockup with pump
Securing Fans
Unsleeved Fan
Sleeved #1
Sleeved #2
Old June 24, 2008, 02:40 PM
Jack Rabbit's Avatar
How are you going to watch the fish with all that grill in the way?
- James Graham
Old June 24, 2008, 02:48 PM
like people at ncix suggested...have you thought of painting the bottom cage black? :P
Old June 24, 2008, 03:11 PM
It will be.. I'm finishing off and boxing in the bottom half before I paint it.
Once its framed in its getting low expansion foamed between the plates for sound deading etc.
If you even had a inkling of the cost gone into this thing so far I'm sure you'd be
Old June 24, 2008, 03:16 PM
looks good man keep up the great work look forward to seeing to what it looks like when its done!
BrainEater's Avatar
Good start !
More pics from diff angles.
heheh
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old June 24, 2008, 03:24 PM
Cardboard box with DSL's Avatar
Cant wait to see the finished product!
Aside from the not so nice silver/black contrast right now, it looks pretty cool.
What watercooling gear are you planning on putting down there?
Old June 24, 2008, 03:34 PM
Right now I have:
1 x custom reservoir
1 x PA120.2 (IF it ever gets shipped to Langley)
1 x MCP355 with Petra Top for pump
1 x D-Tek V2 CPU Block
I may end up going with the D-Tek Vga block too but not 100% yet..
Old June 24, 2008, 03:38 PM
Have you considered going to a 120.3 or dual 120.2s down there? I think it would look pretty awesome with dual rads...
Old June 24, 2008, 03:39 PM
Possibly but the availability of the PA120.3 is pretty scarce and for a single cpu and gpu ... 2 dual rads would be major overkill hahaha.
