  #61 (permalink)
Old June 3, 2008, 02:53 PM
Dashock's Avatar
Ohh and im wondering my motherboard is the Asus A8n-Sli deluxe i have several fans plugged straight into the motherboard via 3 pin connector yet i cannot see what rpm they are running at have i disabled something that is not letting me see it i wanna be able to see the rpm of these fans?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #62 (permalink)
Old June 3, 2008, 03:11 PM
Dashock's Avatar
nevermind i found out only the cpu and cha1 fan will show rpm anyways im gonna go hook up the 2 other fans and do some more cable management be back in 2 hours or so.
Asus P5Q-E
Corsair Cx600M
  #63 (permalink)
Old June 3, 2008, 04:09 PM
Dashock's Avatar
Alright this is with 2 fans Idle temps are about 3-4 degrees down specifically on the cores and load aboot the same loads the first.
Asus P5Q-E
Corsair Cx600M
  #64 (permalink)
Old June 3, 2008, 07:06 PM
magictorch's Avatar
Well 2oc under now but (a bit later so may have cooled down).....are you using MX-2? I think your temps are ok but I guess the trouble is the chip tops out before you can really make the WC shine...anyway it will be a hell of lot better than air over the summer
  #65 (permalink)
Old June 3, 2008, 09:07 PM
Dashock's Avatar
Yep using MX-2 and honestly thinin it out is a lot harder on the cpu as its a bigger surface using the same methods as i did with AS5 anyways i just put a dab in the center and let the block spread it the block is tight on the cpu the motherboard actually was a little curved lol maybe i tightned it to much who knows
Asus P5Q-E
Corsair Cx600M
  #66 (permalink)
Old June 3, 2008, 09:11 PM
Dashock's Avatar
I installed my Antec spot cool fan back to cooling my video card mofset and its doing a number on the motherboard cooling it by another 2 degrees down so thatss awesome i think this project is slowing coming to an end lol i wish i was below ambient on temps but like you said this chip just cannot go anymore further i have used up to 4.725 volts and managed to boot to 2.8ghz but its not prime stable i wonder if 1.5 volts will do it but how much electricity imma waisting bumping it up that much and i dont think it will be stable at that voltage either.
Asus P5Q-E
Corsair Cx600M
  #67 (permalink)
Old June 4, 2008, 12:49 PM
Dashock's Avatar
I got some better Idle temps today
Asus P5Q-E
Corsair Cx600M
  #68 (permalink)
Old June 4, 2008, 01:54 PM
Cptn Vortex's Avatar
Looks very good. now I bet you want to Watercool more!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #69 (permalink)
Old June 4, 2008, 08:52 PM
Dashock's Avatar
duhh but i wont for awhile i wanted to cool my videocard lol i thought i almost screwed up my motherboard fan the northbridge when i ripped it apart some plastic was stuck on the bottom of the heatsink and the heatsink had sum thick sticker on it i ripped that apart then i sadded the block lol then cleaned the crap outta the block with alchol lol - i know people are screamin i was scared i screwed up the chip but applied sum Mx-2 and it booted up straight it runs a lot cooler for sure even when overclocked so was it worth it hell yes but was scary lol.
I will probbaly buy those Thermochill rads i wanna be able to have my cores to 10 degress celcius as some people can have them soo low but i know those are Intel chips dam amds have to run soo much hotter and i wish my cpu could givee me more.
Thanx again Mr Vortex
Asus P5Q-E
Corsair Cx600M
  #70 (permalink)
Old June 5, 2008, 10:04 AM
3.0charlie's Avatar
You cannot have a cpu temp lower than the ambiant temp, either under air or water.
Hydro-Quebec is salivating...
