  #31 (permalink)
Old May 31, 2008, 08:44 PM
3.0charlie's Avatar
Originally Posted by Dashock View Post
so how much of a hit do yu think will iget?
No idea. I never did a loop like that. But like Mr. Wilson wrote, the difference may just be very little. Unless you will eventually add more blocks to the loop.
Hydro-Quebec is salivating...
  #32 (permalink)
Old May 31, 2008, 08:54 PM
Dashock's Avatar
Thanx a lot mr Wilson and just out of curiosity should i wait till those micro bubbles go before i turn on my computer or can i turn it on now and wait for it to go?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #33 (permalink)
Old June 1, 2008, 06:25 AM
sswilson's Avatar
The micro bubbles are going to affect temperatures, but as long as you've done a lengthy leak test and watch your temps you should be OK.
I find turning the pump on for a minute or so, turning it off and letting it settle for a minute or so, then turning it back on for a minute helps settle the bubbles. (repeat as necessary) :) .
  #34 (permalink)
Old June 1, 2008, 07:41 AM
magictorch's Avatar
Default making progress
I just waited for a few hours for the froth to go with intermittent ons and offs..that pump is pretty powerful and whipped the water up into a foam pretty quick.
Ive worked a lot with experimental aquaria/tanks but that caught me right off guard.
  #35 (permalink)
Old June 1, 2008, 04:09 PM
ChuckleBrother's Avatar
I just ran mine with the micro-bubbles, my temps went down by all of 2 degrees by the time they settled, so long as your temps are acceptable you won't have any trouble running them out of the system.
"...you play a mean banjo"
  #36 (permalink)
Old June 2, 2008, 01:07 AM
Dashock's Avatar
i set up my system in the basement and letting it run for awhile i think i got out some of the bubbles as i was able to fill a little more liquid soo its working lol i hope my basement is very cool so im getting good temps my room is hot since its soo small.
Asus P5Q-E
Corsair Cx600M
  #37 (permalink)
Old June 2, 2008, 02:33 PM
SugarJ's Avatar
I've been watching this thread with much interest, I've been seriously thinking about a "simple" loop myself. But here's a question which has been bugging me:
How do you get power to your rad fans? Daisy chain them together and feed a molex connector outside your case?
  #38 (permalink)
Old June 2, 2008, 02:42 PM
sswilson's Avatar
Yep, or you do a mod similar to this.....
  #39 (permalink)
Old June 2, 2008, 02:53 PM
SugarJ's Avatar
Very slick mod Mr. Wilson. I like that, simple and tidy. I'm still toying with the idea of pulling my hdd cages from my 900 and doing an internal rad mount.
Sorry to hijack the thread Dashock. Nice work, BTW.
Edit: did a little searching, here's a $6 fix for the un-handy. 4 power connectors, 2 each of molex and 3 pin.
http://www.ncix.com/products/index.p...re=Mod%2FSmart
  #40 (permalink)
Old June 2, 2008, 04:31 PM
Cptn Vortex's Avatar
Did you leave enough room under the tubes for your Videocard? It is always good to use more tubing, and have the room for upgrades!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
