  #21 (permalink)
Old May 30, 2008, 05:09 PM
Cptn Vortex's Avatar
Mmmm....purdy
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #22 (permalink)
Old May 30, 2008, 06:31 PM
magictorch's Avatar
Default Very nice
So you have all the goodies now.. remember to take your time-and clamp the apogee GT down evenly.
Looking forward to seeing the final product. You can never go back once you water cool-just looks and performs so damn good.........
Good theres so much help here to get people through their first loop.
  #23 (permalink)
Old May 31, 2008, 05:12 PM
Dashock's Avatar
Alright Day 1 Take apart where to start?
Took apart all the hardrives and Videocard to get to the 3.5 bay at the bottom which i found out can be taken out my case is a Thermaltake Vx Matrix lightest case in the world at 2 pounds!
Well now that the case was gutted it was time to take apart the 3.5 bay theres two screws as you will see in the first picture and after several seconds of pulling i found out there 4 more in the bottom silly me ! lol (noob)
Alright after it was taken out i had a lot more space too work with as you can see
but before we got to that to prove how light the case is two fingers were used to lift it up lol
And this is the case after the 3.5 bay was taken out
I decided to install the new thermaltake Icage now just to get it out of the way and i wanted to see how it would look.
Anyways after installing it into my bay i took apart the Zalman 9700 from my cpu and here it is i think it was a pretty even spread of AS5
Clean of with Isopropyl alchol i used the 99 percent one i find it has a good kick and removes AS5 pretty dam quickly one swipe you can get it at Loblaws for 1.99 so its cheap okay i got a little too exicted and took apart my Motherboard northbridge fan and soemthing ripped but i think its alright so if my board doesnt boot i know i screwed up the dam little northbridge i thought id apply some MX-2 to put the temps down.
Ohh and Mx-2 is good its very easy to apply except i had a real difficult time trying to spread it evenly on my cpu i used thin thin cards and usually works perfectly with AS5 but it was abosolutely imposiible so i decided to put a small dab
Image makes the blob look bigger a real grain like blob anyways here is the Apogee GT block with Highflow barbs from swiftech i used a wrench to get it nice and tight and tested if it would leak.
I peeled of the sticker in the bottom and rubbed some Isopropyl and something odd there was a lot of fine scratches on the block i dont know if its normal i was tryin to take a picture of it but as you can see it makes it look like its a mirror finish which it is but there was scratches ? is this normal ?
And here is my block installed on my motherboard all you needed was the two nipples and put the screws in one at a time and its pretty straight forward.
Alright after that was done i proceeded to install the radbox follow the instruction.
Well at this point it was around 1 am and i got bored and thought it was the end of the night for that so went online on XBOX LIVE for some Halo3 booyakasha add me DASHOCK7. The following day started pretty late which is today at 2 pm lol i was up till 5 am on xbox live and well couldnt sleep so started 5 i began proceed my way installing the loop while watching The BEE movie with Jerry Seinfeld.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #24 (permalink)
Old May 31, 2008, 05:55 PM
Dashock's Avatar
DAY 2
Installed motherboard into computer and put in the hose by warming up hot DISTILLED WATER in a cup and it worked like a charm thankyou i cant remmber who told me to do that but worked except for getting the dam hose into the barb of the Pump it was a pain but luckily my dad to the rescue and he magically got it in there lol so i let him take care of both the inlets of the pump. ( Father and son day today it was kinda good experience he enjoyed it a lot of tools were used let me tell you and the sitting room was a mess but we had a good laugh watchin the BEE movie.
I used the smartcoils as insurance and they work and i suggest you get them as you will see some of my turns are pretty bad but the smartcoils to the rescure.
A little bend work i got so fed up with it i just cut it out so it left a big hole.
So i said the barbs on the rad and cpu were pretty easy to install swiftech high flow barbs the barb on the pump is quite much difficult i had to leave the tube in hot water for atleast a min or two to get the dam tube in and to finish it off used some zip ties as mr Vortex sugested.
I proceeded to test my loop by hooking the pump to another computer a sec on till the whole loop was covered in water and did that like 5-6 times anyways and then let it ran for a 1 min then 2 but my loop just gets cloudy full of bumbles is that normal ??? almost looks like soapy water to be honest i have left the rad cap off to let bubbles out but doesnt seem to be helping is this a normal thing and i have to let it run without the cap on for 6-12 hours to get rid of the bubbles??
Asus P5Q-E
Corsair Cx600M
  #25 (permalink)
Old May 31, 2008, 05:59 PM
Dashock's Avatar
So thats where i am at now and that was 45 mins ago that piucture taken when i leave the pump on for more then a min the whole loop gets cloudy like it looks like its soapy water so please tell me its normal and this is the part i leave my pump on for 6-12 hours with the cap off yess???
Asus P5Q-E
Corsair Cx600M
  #26 (permalink)
Old May 31, 2008, 06:27 PM
3.0charlie's Avatar
Couple of comments.
1. most important: I think it's great that both you and your Dad had a blast doing this.
2. it's normal that the liquid becomes cloudy - it's full of micro bubbles. Close the cap, let the pump run. They'll go away eventually.
3. it's not a big deal, but you installed your loop the wrong way. It should be as follows: pump - rad - block - pump. You have rad - pump - block - rad.
Hydro-Quebec is salivating...
  #27 (permalink)
Old May 31, 2008, 06:39 PM
Dashock's Avatar
yOU KNOW what when i was lookin thru the picture i just realized it too that i should have ran the pump the top of the swiftech block instead of the bottom right??/
Now will this hinder performance or something charlie???
Asus P5Q-E
Corsair Cx600M
  #28 (permalink)
Old May 31, 2008, 06:43 PM
3.0charlie's Avatar
top or bottom is no difference. but not having the coolest liquid will make a difference with the CPU temps.
  #29 (permalink)
Old May 31, 2008, 07:28 PM
Dashock's Avatar
so how much of a hit do yu think will iget?
Asus P5Q-E
Corsair Cx600M
  #30 (permalink)
Old May 31, 2008, 08:19 PM
sswilson's Avatar
In a cpu-only loop... pretty well no difference at all.
